Dayne Posted May 17, 2022 Share Posted May 17, 2022 Hello people! I'm about to list this anvil on kijiji and I was hoping to identify it first. The markings have been ground away. All I know is that its 100lbs. It may have come from England as well, but maybe not. Any help at all would be appreciated. Thanks so much Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 17, 2022 Share Posted May 17, 2022 Does it have an indentation in the base; if so what shape? Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 18, 2022 Share Posted May 18, 2022 If you know someone at the local crime lab they can make the stampings readable. You might be able to find the process online. It's why filing the serial # off a fire arm doesn't make it untraceable. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 18, 2022 Share Posted May 18, 2022 Lemon juice has been used to bring up ground off stamped in numbers on firearms and engine blocks. Quote Link to comment Share on other sites More sharing options...
Dayne Posted May 18, 2022 Author Share Posted May 18, 2022 Okay, thanks. I'll look into this. As for the bottom, its nailed to this stump with bent over rebar. Seems to work well and I'll have to probably straighten them rather than pull them out. Anyway I'll get a pic of what the bottom looks like. Quote Link to comment Share on other sites More sharing options...
Dayne Posted May 18, 2022 Author Share Posted May 18, 2022 Here's the bottom. Doesn't seem to be anything at all. Quote Link to comment Share on other sites More sharing options...
Dayne Posted May 19, 2022 Author Share Posted May 19, 2022 On 5/17/2022 at 4:16 PM, ThomasPowers said: Does it have an indentation in the base; if so what shape? Here is the bottom Quote Link to comment Share on other sites More sharing options...
