natkova Posted April 8, 2022 Share Posted April 8, 2022 Welli did some upgrade on my bellows. Want to show ideas to others. Chain Is a lots of better than rope for pulling bottom chamber and I added some bearings to pole. Here are pictures, maybe it can help someone. Bearings are welded to rod which is bolted to wood and iron frame Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted April 8, 2022 Share Posted April 8, 2022 Looks like the chain an bearings would definitely make a difference! when you welded the bearings to the rod did it not melt out the grease seal? Quote Link to comment Share on other sites More sharing options...
natkova Posted April 10, 2022 Author Share Posted April 10, 2022 On 4/8/2022 at 5:29 PM, TWISTEDWILLOW said: Looks like the chain an bearings would definitely make a difference! when you welded the bearings to the rod did it not melt out the grease seal? Well i didn't noticed that. i think its not big problem even if it melt grease it will rol in it. One thing to notice you need to cool down wood because it will burn! I used water and cooled wood while i welded / i know its bit dangerous / but i had to do it like that. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 10, 2022 Share Posted April 10, 2022 The bearing is the pivot for a lever, not a rotating shaft so if the bearing lost it's temper it's not a problem. The grease probably kept it cool enough to hold the temper anyway. I must say you have a real talent for finding awful lighting for your photos. Of course it DOES have us looking closely for longer to see what you want to show us so I guess the trick works. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted April 10, 2022 Share Posted April 10, 2022 I was more worried about debris getting in the bearing and jamming it up over time then the temper, but like you said it probably won’t be a big deal since it’s not fully rotating Quote Link to comment Share on other sites More sharing options...
natkova Posted April 10, 2022 Author Share Posted April 10, 2022 1 hour ago, Frosty said: The bearing is the pivot for a lever, not a rotating shaft so if the bearing lost it's temper it's not a problem. The grease probably kept it cool enough to hold the temper anyway. I must say you have a real talent for finding awful lighting for your photos. Of course it DOES have us looking closely for longer to see what you want to show us so I guess the trick works. Frosty The Lucky. Well i cant relocate my shop maybe i could take picture in morning instead in evening, Sun will shine on other place. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 10, 2022 Share Posted April 10, 2022 I'm just poking a little fun at you but it might make a difference. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted April 11, 2022 Author Share Posted April 11, 2022 I am planning to add some pulleys or some triangle handle which hang from pole, since its too high. Back stroke is dangerous well lets say pain full because it have weight on bottom chamber, so It pull bottom chamber faster. Quote Link to comment Share on other sites More sharing options...
