January 1, 200620 yr Lard was used for many years as a cutting oil for lathes, drillpresses, taps and dies. Bacon grease will also work. Peanut oil will work for cutting fluid. Kerosene will work as a coolant.(be aware of fire hazard) Milk will give a nice finish on copper when used as a cutting fluid. Old solvent (that has been strained through a paint filter) works good on alum.& mild steel as a coolant.(be aware of fire hazard) Crisco works well in about all tapping situations. *
January 1, 200620 yr Never, ever use motor oil! If oil was so good as a cutting fluid, it would never have been used to inhibit friction in engines. I use water or the non-flammable brake-cleen as a coolant. Also makes the iron ready for paint, or if it has to back in the fire, there isn't a foul smell or smoke.
January 1, 200620 yr WD40 also works well on aluminum but plain old water is pretty good on almost anything. A very small amount of emulsifable oil makes it slicker, which is why most of the modern coolant "brews" are nothing more than oil suspensions that can be added to water. I have about three gallons of Cincinnatti's proprietary concentrate but it's a 30:1 recipe - 90 gallons of mix would serve my great-grandkids... I still use unsalted lard for tapping and threading on the lathe but bacon grease has salt and will eventually rust your work if you don't take the time to clean it.
July 21, 200719 yr the best cutting oil I have used is a 50-50 mixture of pale oil and diesel fuel-and, it works on most materials!
July 21, 200719 yr How about green Palmoliove dishsoap for a lubricant. One of the few items that still has an animal fat in it. Use on drill press .
November 3, 200718 yr i have tryed jiff it worked real well its a white grit like cleaner don't know how hard ti is on the tool----
November 3, 200718 yr I like WD-40 for aluminum, and use a cool water soluable oil stuff for everything else.. theres no mess, it sipes off like water.
