wrenchguy Posted January 30, 2022 Share Posted January 30, 2022 I believe it was fastened to a vertical surface because of the curved reinforcement bulge of the casting along its bottom. The grease cups may indicated its got roller bearings. Is there a specific term used for style of grinder? Thanks for looking. Front. Rear. Right end w/ mounting holes. Left end. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 30, 2022 Share Posted January 30, 2022 Interesting, it might be part of a machine that needed the product ground as part of the production steps. I picked up 4-5 grinders similar to this, not as odd but all belt driven bolt downs. I got them for, "just get them out of here. I was thinking of mounting them on a turn table with a single 1hp motor in the center. I thought I could turn the table, switch the belt over and present a different grinder, wire wheel, buffer, etc. When I got them home and unloaded I realized that like yours I'd have to remove the shaft to put a belt on it. So much for the quick change idea and no wonder the guy had his kid loading them in my truck before I got a good look. The bearings on mine are porous bronze and one is babbit. They all turn free and easy and I could use modern belts that can be opened but I have a lot of back burners ahead of that "I wonder if" project. Let us know what you do with it, I'm always looking for good ideas even if I don't have anything to do with it when I see it. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted February 10, 2022 Share Posted February 10, 2022 A few years ago I saw a odd ball flat belt grinder setup on Craigslist, it had a cast iron stand an was probably around 5 foot wide, the flat belt drove the shaft and there were quite a few setups on it for cutting, buffing, grinding, wire wheel ect.. and a blower that collected all the dust, the person selling it said it came from an old shoe factory, Quote Link to comment Share on other sites More sharing options...
