July 24, 20214 yr I'm putting together a 20lb propane tank forge with two 1/2" Frosty T burners... I'm trying to sort out the plumbing to the burners and picked up a couple 2' long 1/2" stainless steel gas heater/dryer connector hoses to hook directly to the burners - at the other end they'll each go to a ball valve, then a Tee, then to my 3/8" propane supply hose, regulator, and 20lb supply tank. Looking at the parts, I'm now wondering if there is an issue going from a 3/8 supply hose up to two 1/2" hoses before the burner - I feel like gas lines usually go from larger to smaller diameters... But I figured the regulator would keep it all at the set pressure regardless and the burners wouldn't notice any different. Did I figure wrong?
July 24, 20214 yr It won't cause problems but you certainly chose a more expensive way to plumb your burners. Frosty The Lucky.
July 24, 20214 yr Good Morning, We have a meeting tomorrow Sunday morning, 11:00am. Luxton Fairgrounds, 1040 Marwood Ave. Victoria. Bring what you have. we can help you. The Blacksmith Shop will open about 9:00am. Bring a chair and a bowl for coffee. Meeting will be outside the Shop. Vancouver Island Blacksmiths Association (VIBA) Neil
July 25, 20214 yr Author Thanks Frosty for clarifying - those hoses were actually cheaper than any regular hose I was able to find and I didn't want to go with copper because the forge will get moved and likely bumped a lot. I do like that they are steel and not rubber/plastic next to the burner too. Thanks Neil - I flaked out and forgot about the meeting tomorrow! See you there
July 25, 20214 yr That makes perfect sense. I'll have to keep them in mind if the situation comes up. Frosty The Lucky.
