The budget blacksmith Posted April 23, 2021 Share Posted April 23, 2021 So I've got this old 40 ton hydraulic ram with a leak where the shaft goes in and out of the cylinder and I'm having trouble getting it apart. It's a 5.5 inch bore wire spring cylinder and I have been unable to find the Grove filler of that size does anyone know where to find one or something to fill the Grove with. Thanks Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 23, 2021 Share Posted April 23, 2021 Have you tried the manufacturer of the cylinder or a hydraulic equipment repair shop for parts? Quote Link to comment Share on other sites More sharing options...
Anachronist58 Posted April 23, 2021 Share Posted April 23, 2021 By groove filler, do you mean seal? First order of business is to post an image of the area in question, next, assess what is needed for disassembly, and then (seals?), etc., might be discussed. But before all of that, you might ask to have your topic moved to the proper section of the forum, such as problem solving? Oh, and, or what Glenn Said? Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted April 26, 2021 Share Posted April 26, 2021 What Glenn and Anachronist58 said.. Quote Link to comment Share on other sites More sharing options...
