ede Posted December 20, 2020 Share Posted December 20, 2020 I’m in the process of making a stock rack and came across some 10’ bars that I can’t identify. Does this look like old paint? I think I’m gonna recycle them instead of risk heating them up as I have a ton of new stock 3/8” and 1/2”. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 20, 2020 Share Posted December 20, 2020 It doesn't look like galvanized to me. Were you thinking of using it for forging stock or to build a stock rack from it? If for forging, I would cut a short piece off and put it in a vinegar soak to see if the finish that's left comes off. One can never have too much stockand a job that this can be used on may show up. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 21, 2020 Share Posted December 21, 2020 Also do a spark test or a notch and break test for wrought iron in case they are *OLD*. Quote Link to comment Share on other sites More sharing options...
arkie Posted December 21, 2020 Share Posted December 21, 2020 ede, if you do a break or bend test, this is a comparison of wrought iron vs. mild steel. The wrought iron should have a fibrous texture (fine to coarse, depending on the quality of the WI). The mild steel should show a uniform microcrystalline structure. This wrought iron came from the Old Globe grain warehouse in the Superior, Wisconsin area. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 21, 2020 Share Posted December 21, 2020 If it checks out to be wrought iron, you have a really great find. If it were me, I would be looking for more. Quote Link to comment Share on other sites More sharing options...
ede Posted December 21, 2020 Author Share Posted December 21, 2020 1 hour ago, arkie said: ede, if you do a break or bend test, this is a comparison of wrought iron vs. mild steel. The wrought iron should have a fibrous texture (fine to coarse, depending on the quality of the WI). The mild steel should show a uniform microcrystalline structure. This wrought iron came from the Old Globe grain warehouse in the Superior, Wisconsin area. Thanks for the photos, Arkie. On the larger pieces when i cut it in half the other day with a diamond blade chop saw, I did see carbon sparks-I was also thinking potentially wrought. Maybe the smaller rods are, I will check them out. Quote Link to comment Share on other sites More sharing options...
ede Posted December 21, 2020 Author Share Posted December 21, 2020 4 hours ago, Irondragon ForgeClay Works said: It doesn't look like galvanized to me. Were you thinking of using it for forging stock or to build a stock rack from it? If for forging, I would cut a short piece off and put it in a vinegar soak to see if the finish that's left comes off. One can never have too much stockand a job that this can be used on may show up. Oh, I believe there actually can be a problem of too much stock, I can attest to that. The smith that used to forge here that passed away held onto every last drop and it was everywhere. It can become a non-functional shop and walking hazard by having too much stock. Here’s some 20’ bars I cut in half the other day, and I still have tubing, angle iron, sucker rod, tool steel, ornamental iron from Kings, and much more to go. I will post another picture of a vertical stock rack I added this year, either on this thread or a new one. I have held on to so many short pieces and sorted them in buckets. In the end I feel like it’s kinda a false economy because precious space is lost. For the stock rack I think I’m going to use tubing as it’s more rigid and will be holding lots of weight! Quote Link to comment Share on other sites More sharing options...
