sources for magnets
If you open up a discarded hard drive, at the base of the swing arm are two small very powerful rare earth magnets. If you let them click together they are hard to separate w/o a tool. Caution opening up a hard drive will almost surely ruin it for computer use.
In old microwaves you can find a pair of nice ring magnets about 3" dia inside the klystron which looks like a tin can with fins on in usually mounted at the top and back. Pull the can apart to find the magnets. There is also a big high voltage cap usually at the back which looks like a flat tin bottle with terminals. I like to short this out first by putting a screwdriver across the terminals just in case its still holding a charge. I have never seen a spark but its a simple precaution.
Hey Maddog,
Give these folks a try.
I incorporate rare earth magnets in my wood-work to hold metal elements in place.
Good selection, fast shipping, economical and no electrical shock risk!
Amazing Magnets
Electronics repair shops regularly discard large loudspeakers that can't be re-coned.
They have large dough-nut shaped ceramic type magnets that are quite powerful.
You can remove the magnets with a screw or nut driver usually.
7644.attach
7645.attach
Sonicare electric toothbrushes have replacable heads. I take the wore out heads and pry off the two tiny,yet strong magnets off the bottom. They're great for holding notes on the steel shop door.
I have a couple of speaker magnets on the inside wall (sheet metal) of my shop---they are growing "hair" on the outside as the wind blows ferrous dust around the building...
One way to collect iron ore!
  • 3 months later...
A VERY cheap source for strong neodymium. (I have bought from them, and they are both reliable and fast.)
eBay Store - magnets: wind turbine, flexible magnets windmill blades, rare earth magnet
Neos (Neodymium rare earth) are really good, as a small fifty pound pull sucker (1" diameter by 1/2" grade N50 ) can be used at a distance to tell if steel has gone non-magnetic, without the hot steel being close enough to really damage the magnet. Just don't try to touch the steel to the magnet..... even with cold steel. These are POWERFULL. :o
No, I have no connection other than being a happy customer of theirs.... :D
Paul Andrulis
