Posted
Happy Friday, smiths.
I'm thinking about my chimney. It currently exists only in my brain, so there are no pictures. Here's the setup:
- The forge is an old bottom-blast rivet forge with a Buffalo blower
- My shop is a 10' x 8', plywood walls
- The doors do not seal at all; wind does not blow through, but it's drafty
I live in Minnesota and hope to forge primarily during the winter; the air outside the shop will be cold
- I plan to use mainly charcoal for fuel, but I have access to cheap coal through my local guild
- My chimney will be 10" diameter, about 9' long, with a fairly close-set hood
So, the question: do you think I'll be able to get a solid draft with the doors closed? Do I need to worry about burning up all the air in the room, or will the hot air going up the chimney pull in fresh air from the open seam of the door?
Posted
You'll be surprised how "drafty" your shop is.  Most people have no idea how many air leaks they have in  their homes..............but their fireplaces wouldn't burn if the houses were air tight.  I wouldn't over think your chimney problem.  If you find you don't have enough draft, then crack your door a bit.
