August 1, 200817 yr Just got an old well tank. About 4-5 ft. tall and about 2-3 ft. diameter. Any1 know what type of material this is?
August 1, 200817 yr I spent 9 years building pressure vessels. A large number of ours we made from A203E. The nickel content gives this steel strength against internal pressure.
August 1, 200817 yr Coltpax if I might make a suggestion. Take some steel you know what it is and can research how to work it, how to annel it how to harden it etc. (ie 1095) That way you know what is supost to happen and if it doesn't happen you know you made a mistake. If you start with an "unknown" you wont know if it was something you did or if it was a fault in the metal. I make things out of "junkyard" steel but not knives because I am still learng. So get a piece of good steel and start from there if you want to make a good knife. Just my opinion William
August 1, 200817 yr Coltpax, A203E is good for giving damascus contrast due to the nickel content. By itself it won't make a good knife.Triw is giving you good advice in his above post. Good luck.
August 1, 200817 yr typical drinking water well tank is galvanized mild steel. Not anything fancy at all! Not good for knives. Try a car coil spring instead.
August 1, 200817 yr Leaf springs are good for knives also and are easy to get your hands on. welder19
August 1, 200817 yr It looks like there are 2 thoughts running here. One on pressure tanks the other on "cistern" type tanks. Can you say which your's is? ron
August 2, 200817 yr Author i really absolutely cant say. i now about leaf springs, and i have been trying to get some. but, i did get 3 big saw blades from a saw mill to use.
