Mark M tx Posted May 26, 2020 Share Posted May 26, 2020 I got this blower with forge. It stopped and my son changed it out with a cheap one. I would like to get it working again but cannot get the handle to turn. I can hand turn the fan and see the gears turning. Will try and attach photos. This is as far as I can get broken down. Pretty new at this and not very handy. Ideas? Well can't figure out how to post photos Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 26, 2020 Share Posted May 26, 2020 Welcome aboard... I always suggest reading this to get the best out of the forum. It is full of tips like editing your profile to show your location as so many answers require knowing where in the world you are located. READ THIS FIRST Other tips deal with doing the most effective search, editing/uploading pictures and some may help with flying under the moderators radar. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 26, 2020 Share Posted May 26, 2020 What model of a buffalo forge blower? Has the gearbox been thoroughly cleaned out and reoiled? (Don't remove the gears!) Sometimes a gear can slip out of alignment and you have to figure out why and tweak it back. Quote Link to comment Share on other sites More sharing options...
Mark M tx Posted May 27, 2020 Author Share Posted May 27, 2020 I am not sure on the model. I got some tips for this forum and am trying to reduce photo pixels so they will load. I got the nuts off the plate that covers the gears but cannot get the plate off. I will do a better job the next time I post and perhaps later this week I can get the photo issue solved. Thanks for the response. Mark Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 27, 2020 Share Posted May 27, 2020 Some blower gear casing caps SLIDE "uphill" to release after removing the screws---don't break it trying to pry it straight up! Quote Link to comment Share on other sites More sharing options...
Mark M tx Posted May 30, 2020 Author Share Posted May 30, 2020 Sorry I can't seem to get a photo to load they take up too much space. Fan turns gears and turns shaft some that way. But shaft will not turn by itself to turn gears. I wish I knew how better to explain. I obviously am not very mechanically oriented. I will try and get my kids to show me how to change photo to less pixels. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 30, 2020 Share Posted May 30, 2020 I do a "save as" of pictures from my phone after I email them to my computer. I save them at file sizes under 300 kb. and they have no problem loading. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted May 30, 2020 Share Posted May 30, 2020 If you have a windows 10 computer, open photos and with photo open, select the 3 dots on the right hand side of the screen.. This will bring up edit options and a resize option, Pick 2K for emails and such. it could be as simple as a bunch of gunk inside. The gear drive could be a 48/1 and this means it does not take much to hold the handle from turning as the fan blade will move 48 revolutions to the 1 hand crank.. Be gentle so as not to damage anything. Quote Link to comment Share on other sites More sharing options...
Mark M tx Posted May 30, 2020 Author Share Posted May 30, 2020 Thanks for the advice. I will try that with the photos. Quote Link to comment Share on other sites More sharing options...
