swedgemon Posted March 14, 2020 Posted March 14, 2020 (edited) My DW has been asking for a coffee table for several years...a few good pieces of oak finally came out of my firewood logs. After a lot of planing, sanding, forging, some welding, wire-brushing, etc., I came up with two (I usually make things in "2's") that have a good "wow-factor". The larger table is 61"L X 16" to 19"W X 14.5"H, the shorter table is 56"L. The oak slabs are a bit less than 2" thick...they both have great grain. The black splotches are where I filled various holes with clear epoxy. Wood finish is a coat of polyurethane, sanded with 320-grit, then a coat of Minwax Golden Oak...DW put some kind of furniture polish on them for a dull glow. The legs are 1.5" square tube, battered and beaten under the power hammer - they are set at 5-degrees apart and a few degrees "out". Notice in the photo of the legs I used a shim to soak up some wobble. The legs are welded to pieces of 1/4X3X14 flat bar. The end braces are 1/2" square. tapered and twisted, the tie rods are 3/8" square, twisted and "hooked". The turnbuckles are from the hardware store, beaten and battered. Leg wraps are 1/4" round, tapered on both ends, wound on with a rosebud, pliers and a small hammer. Metal finish is wire brushed then a few coats of Rustoleum Clean Satin Enamel. Moving these things is a two-person event, but I would guess the load rating is around 1,500 pounds. DW is keeping the larger table...happy wife = happly life...maybe I'll find a buyer for the shorter one. Edited March 14, 2020 by Mod30 Resize large photos. Quote
Awrksmokey Posted March 26, 2020 Posted March 26, 2020 They look great! I like the wrapped steel rod, it's a nice touch. Quote
Justin Topp Posted March 27, 2020 Posted March 27, 2020 Love it!! And that oak has so much character Quote
