MacLeod Posted January 27, 2020 Share Posted January 27, 2020 This is a straight forward cry for help. I’ve tried both ways and still can’t really work out which is better. When I make rams head implements I normally finish with beeswax and blo which darkens them nicely, but I do love a brass brush finish. What should I put on first? My small brain tells me the brass won’t stick on top of oil yet I find that for a brass brush finish the heat is a bit lower than for a good blo finish. I’m going round in circles Any tips? I couldn’t find the answer in the ifi tomes. Quote Link to comment Share on other sites More sharing options...
Glenn Posted January 27, 2020 Share Posted January 27, 2020 Brass brush transfers brass to the warm metal making it look brass or golden. It has no ability to seal the metal from moisture or oxygen. Bees wax or BLO is a protective coating or sealer for the metal to keep moisture or oxygen away from the metal. If you use the sealer first you will burn it off when you heat the metal in order to transfer the brass from the brush to the metal. Use the brass brush first then seal the metal. Quote Link to comment Share on other sites More sharing options...
MacLeod Posted January 28, 2020 Author Share Posted January 28, 2020 Gotcha. It makes sense when someone who knows says it. Thanks Glenn. Quote Link to comment Share on other sites More sharing options...
anvil Posted January 28, 2020 Share Posted January 28, 2020 They both apply at about the same temp in the black heat range. Brass brush first and in the same heat, apply blo, turps, beeswax mix. It will make an "antique brass" look to die for. Quote Link to comment Share on other sites More sharing options...
MacLeod Posted January 28, 2020 Author Share Posted January 28, 2020 1 hour ago, anvil said: antique brass" look to die for. That’s what I’m looking for! Thank you Anvil Quote Link to comment Share on other sites More sharing options...
anvil Posted January 29, 2020 Share Posted January 29, 2020 Glad to help. When it cools, clean it with alcohol to get the grime off of it. Then apply cold a carnuba based furniture polish and buff it up. Quote Link to comment Share on other sites More sharing options...
