Buying a forge
On 1/19/2020 at 12:48 AM, MCalvert said:
Does the company provide rigidizer, cast-o-lite equivalent, and Plistix? These necessary things may be extra costs to consider.
I could be wrong, but don't think rigidizer is a good choice on rigid ceramic board. coating layer materials are fine,  though.
Ditto, rigidizer isn't a high temp material and board doesn't release fibrous particles in near the quantities blanket does. A hard flame face should be more than enough.
  • 7 months later...
Thank you for the replies - I didn't realize that iForge wasn't sending me notification when people replied so I just saw the responses now!
I ended up getting some el-cheapo firebrick (not the soft kind) from Rona and and use a bernzomatic torch hooked up to my bbq propane tank.  The interior is only one brick thick and maybe a couple of inches wide, but it's been enough to make a bunch of napkin rings with leafs on them and to heat treat a stock-removal knife.
I used some charcoal for a big enough fire to make some really really ugly tongs.
But I've found some suppliers for kaowool and refractory cement etc, and found that my brother in law has a drill press as well as a wielder, so I think I'll make a propane-tank forge at some point!
  • 1 year later...
Wow, I haven't been on here for 2 years and did not see any of your responses. Thank you all for your time, its been awhile now and i have not got rigidizer for the forge. I did realize I did not need that, sorry for not responding to any of you it was rude of me, but i did not get any notifications of anything.
Thank you,
-Matthew H
