edennis Posted December 7, 2019 Share Posted December 7, 2019 I'm wondering if a stainless steel forge chimney will react with galvanized brackets due to galvanic corrosion on an exterior wall? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 7, 2019 Share Posted December 7, 2019 My wood stove double wall stainless chimney is held to the outside wall with galvanized brackets and haven't been a problem for the past 30 or so years Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 8, 2019 Share Posted December 8, 2019 On 12/7/2019 at 10:38 AM, edennis said: I'm wondering if a stainless steel forge chimney will react with galvanized brackets due to galvanic corrosion on an exterior wall? No, nor will the galvanized brackets react to the SS. If you use stainless nails or screws the brackets should be safe from stuff you can't see in walls, etc. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
edennis Posted December 9, 2019 Author Share Posted December 9, 2019 Awesome! Thanks Frosty. Just what I wanted to hear. I wasn't looking forward to finding or making stainless brackets. Quote Link to comment Share on other sites More sharing options...
edennis Posted December 9, 2019 Author Share Posted December 9, 2019 On 12/7/2019 at 5:09 PM, Irondragon Forge & Clay said: My wood stove double wall stainless chimney is held to the outside wall with galvanized brackets and haven't been a problem for the past 30 or so years Amazing. That's what I want to hear! Quote Link to comment Share on other sites More sharing options...
bluerooster Posted February 18, 2020 Share Posted February 18, 2020 My fireplace in the house is double wall flue, stainless liner, with galvanized outer, no worries. Quote Link to comment Share on other sites More sharing options...
