First Burner Build
Thread protectors:  have you asked any old plumbing shops if they have a 5 gallon bucket of them under a workbench somewhere?
Yes sir, I have. Around here, all the black steel pipe nipple comes with plastic thread protectors. They don't even bother taking them off of the pipe. They allow the customer to do that when they're ready.
Edited by Mod30
Remove quote
And did they use the plastic ones 20+ years ago?  (Please don't call me Sir---I work for a living!  Surly is ok and Shirley is right out!)
All I know for sure is when I asked if they had any, they said "No"...
On a different note, I absolutely love a good "Airplane" reference. Well played...
19 hours ago, Frosty said:
You got it, that's exactly right. Just remember the really important thing is keeping the gas jet aimed as close to the center of the mixing tube as possible. Folks who don't understand this and mount their jets at or even in the mixing tube MUST use smaller higher velocity jets to entrain enough air to be neutral. Knowing this basic thing about induction devices is why I can put 0.035 contact jets in mine where other folks are swearing and sweating trying to get one to work with 0.025 or smaller jets.
All right, thanks. It seems that adjustable jet position would be a nice addition to most/all(?) types of burners - but perhaps not always worth the extra work, if you're just going to tune it once and then leave it alone.
IgnrntNewb  I am not sure what stores are around you but here is a link to a 3/4 in coupler that you could cut in half and use as a thread protector. It is thin walled and not cast so it should work for you. I am sure you can probably pick these up and any major plumbing supply.
 Remove commercial link per TOS
Edited by Mod30
Thank you, sir!
Edited by Mod30
Remove quote.
Found these on Amazon. They should be here tonight...
Edited by Mod30
