Benona blacksmith Posted November 20, 2019 Share Posted November 20, 2019 So I was curious if it would/could possibly cause issues with my hammer running it at a lower RPM than recommended? Issues like not oiling enough or not being able to "pull" enough oil from the oiling system? I'm just curious because I experimented with slowing it down for a brief moment to drive a drift really slow....kinda like "pushing" the drift vs. driving it in. I have enough control as is. I was just curious if I felt the need to slow it down in the future I don't wanna damage anything. Thank you My hammer is a TZ runfa 88lb/40kg Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 20, 2019 Share Posted November 20, 2019 I sure wouldn't. If you don't have enough control with the treadle you need more practice. A really good way to practice hammer control is to forge strap stock, say 1/4" x 1" on edge into square, then round. 1/8" is of course touchier but I've done it playing with a Nazel 3b. I'd never used one and I wasn't going to be there long so I was seeing what I could do on it. First I gave a piece of medium red, 1 1/4" square "Pure Iron" bar one seriously hard smack that reduced to a round spatula, cut the thin off and forged more down to about 1/8" thick I don't recall how wide, I didn't measure but somewhere between 3/4" and 1" wide and then forged it back down to square. The control was so exquisite I get shivers remembering it now, 15 years later. I can't see a good reason to slow the motor and take any possible chance of oil problems, the gears and cylinder of that Nazel were fed from a crank shaft and the oil pump was supplied from splash off the main drive gear. I have no idea why they did it that way but . . . Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Benona blacksmith Posted November 20, 2019 Author Share Posted November 20, 2019 I have plenty of control....I just took one heat with it slowed down and I was absolutely amazed at the added control slowing it down a bit did. I can close a matchbox with it at it's full rated speed. But if there is a possibility of it damaging my machine it's not worth it!!! Quote Link to comment Share on other sites More sharing options...
marcusb Posted November 20, 2019 Share Posted November 20, 2019 I do not see how it would cause it any damage from a mechanic point of view. Quote Link to comment Share on other sites More sharing options...
basher Posted November 21, 2019 Share Posted November 21, 2019 I have run a few of my hammers at different speeds through a VFD , and you can most certainly get much finer control from a little slowing down of the hammer or indeed sometimes a little more power from very little speeding it up! I found that on the hammers I tried there was a sweet spot for power and a different slower one for best control. I don't know how your oiler works (vacuum?) but I would monitor the oil consumption and check you are getting a film of oil to the front ram. I have just purchases a VFD for my sahinler 110lb hammer to do just the same thing. Quote Link to comment Share on other sites More sharing options...
Benona blacksmith Posted November 21, 2019 Author Share Posted November 21, 2019 Thank you for your input. I believe it runs on vaccum it is the "C41" just like the anyang but cheaper. I'm not sure if the oiler works the same but I did make sure it was dripping at one drop every 5-8 seconds like it is recommended. I'm going to play with it and make sure the front ram (tup?) Is getting oil. I know when it was running faster than recommended it was an absolute animal but got quite warm!!! Quote Link to comment Share on other sites More sharing options...
