Buffalo forge post drill
Hi guys, I recently acquire a buffalo forge post drill as a restoration project.
All the gears and such are in good condition only the drill shaft doesnt want to rotate, what do you guys suggest is the best thing i can do to knock it loose without breaking the cast frame?
Damian Stil
Do you have a product called Kroil over there? I have used it to loosen a few stubborn things in the past. When I have something that needs a penetrant, I spray some Kroil on it every day or 2  for  as many times as it requires until it moves easily, I do not force it. Remove the excess when you take it apart.
