GrumpyBiker Posted October 5, 2019 Share Posted October 5, 2019 I found an old swage Block but all the holes in it are round, none of them are square. Is that unusual & is it something I should be concerned with. Its 2.75” thick , 75-80lbs & $150 Would it be worth it at $2 per lbs even without the square Hardy’s? Condition is fair to good. Needs cleaned up but nothing broken. I know, I should have taken a pic but I’m considering stopping back by. Opinions needed. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 5, 2019 Share Posted October 5, 2019 What would you use a swage block to do in your shop? Are most of the holes in a swage block larger than the normal stock you use anyway? When was the last time you forged 2 inch square, or needed a large round tenon? Photos of the block would help. Quote Link to comment Share on other sites More sharing options...
GrumpyBiker Posted October 5, 2019 Author Share Posted October 5, 2019 For my use it’s the concave shapes on the edge that I’d be using most and at that price it’s equal to buying 3.5 hardy tools with a few of those shapes. But it’ll take up more space than hardy tools.... I’m kinda stumped. Quote Link to comment Share on other sites More sharing options...
Glenn Posted October 5, 2019 Share Posted October 5, 2019 If you have use for it, then go for it. Speaking of stumped, you ever make a divot in the end grain of a wooden stump? Makes a negative bottom tool with many uses. Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted October 5, 2019 Share Posted October 5, 2019 Good Morning Biker, There is no such thing as a Swage Block that will do everything. I have a few and flip them around as needed. If you are doing the same thing, a lot, you can make your own Swage Block with a scrap from under the cutting table. There is no rule that it "has to be" a certain dimension or grade of steel. There are quite a few places that cut odd shapes, which leaves behind 'odd shaped' drops. Don't create "the Box" that might curtail your imagination and vision. The Journey has no 'Time Line'. Neil Quote Link to comment Share on other sites More sharing options...
GrumpyBiker Posted October 5, 2019 Author Share Posted October 5, 2019 Here it is. I suppose I could do worse for $150 Quote Link to comment Share on other sites More sharing options...
GrumpyBiker Posted October 6, 2019 Author Share Posted October 6, 2019 Well it turned out to weight 102lbs. $1.47 per pound. 3”x12”x12” Quote Link to comment Share on other sites More sharing options...
GrumpyBiker Posted October 8, 2019 Author Share Posted October 8, 2019 And so the clean up begins Quote Link to comment Share on other sites More sharing options...
