picker77 Posted September 20, 2019 Share Posted September 20, 2019 I have the usual sliding half-firebrick door setup front and back on my little single-burner, but I've been sort of winging it on how much and when/if to close the back doors. How much is too much? The front doors of course need to be open wide enough to get stock in and out, but is there a general rule of thumb for the back doors (assuming a stock length that doesn't require them to be open)? Seems I read somewhere the color of dragon's breath out the front is a visual key, but I can't find that comment again. I have tried closing the back all the way, and the forge runs ok like that and it doesn't seem to restrict the burner, but of course that results in a rather nasty blast out the front, which can sometimes make stock handling a little more uncomfortable. Quote Link to comment Share on other sites More sharing options...
timgunn1962 Posted September 20, 2019 Share Posted September 20, 2019 The real answer is "whatever works best for you". There are waaay too many variables for a single answer to cover all the possible scenarios. Even the color of the DB will vary in different ways with different setups: some will tend to richen up more than others once the openings become restricted. Quote Link to comment Share on other sites More sharing options...
picker77 Posted September 20, 2019 Author Share Posted September 20, 2019 Thanks, Timgunn. Well, I must be somewhere in the ball park, because what I'm doing appears to work. I just didn't have any real idea what too much closure might do to the burner mix, or back pressure, or CO output, all some of the things that are still a bit of a mystery to me. I do keep a CO monitor on the wall about 8 feet away and I watch it closely, so I suppose I'm ok. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted September 21, 2019 Share Posted September 21, 2019 You just need to run your equipment somewhat longer, and you will answer these questions for yourself Quote Link to comment Share on other sites More sharing options...
