NickOHH Posted August 4, 2019 Share Posted August 4, 2019 Hey all, it's been awhile since I've been around here but I just picked up this post drill and have cleaned it up, reassembled and mounted it , but when cranking the handle the pinion gear on the crank and the smaller gear above it to drive the flywheel are binding at one spot , I loosened the set screw and rotated the flywheel gear and it changes when it binds . There is a little but of play in both gears should there be bronze washers in between to take up the play or do I just need to keep playing with the flywheel gear to get it properly aligned , it seemed to spin fine before cleaning. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted August 4, 2019 Share Posted August 4, 2019 Sounds like they may be too close together and binding. Gears need a little backlash. I usually set gears like this with a piece of paper between them to get a .004" clearance. Quote Link to comment Share on other sites More sharing options...
NickOHH Posted August 4, 2019 Author Share Posted August 4, 2019 I figured it out, ended up being the pinion gear on the spindle, I used a thinner washer under the gear, I think it was changed at some point, gears mesh fine now and it runs smooth Quote Link to comment Share on other sites More sharing options...
