Where to get anthracite in Austin TX
I discovered that Tractor Supply only stocks it seasonally and the local Centaur has closed down.  Is there a more consistent source of coal or coke around here?  I currently have some bituminous coal and some coke (~25 lbs. each), but I am trying to set up a forge at a Makerspace and don't want to tap into my own supplies if I don't have to.  I used to see this stuff advertised on Craigslist a lot, but not lately.  I will go to charcoal if I have to, but I would rather use coal.  Propane isn't in the budget (not the fuel, but the forge).
Thanks,
Rob
