markh Posted July 3, 2008 Share Posted July 3, 2008 I'm thinking of buying a propane forge instead of building one. Does anyone have a suggestion on brands that proven in the area of forge welding? Thanks Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 4, 2008 Share Posted July 4, 2008 It depends more on your technique and flux than temp. Most commercial forges will hit high enough temps to weld. I watched a couple guys forge welding at low orange a few years ago using EZ Weld and Swan fluxes. Frosty Quote Link to comment Share on other sites More sharing options...
me miller Posted July 4, 2008 Share Posted July 4, 2008 (edited) check out uncles als forges Edited July 4, 2008 by me miller Quote Link to comment Share on other sites More sharing options...
civilwarblacksmith Posted July 4, 2008 Share Posted July 4, 2008 When welding with a coal forge, you are watching for the color of the flame to change as well as the metal color equallying the surounding fire and slight sparking. With a gas forge, you are wanting to look more for the movement of the flux. The metal doesn't need to be a high yellow to white, but when you see the flux seem to have fluid motion you will be able to weld. Quote Link to comment Share on other sites More sharing options...
Jerry W. Posted July 4, 2008 Share Posted July 4, 2008 You might want to check out Gas forges - Blacksmith forges and knifemaker forges guaranteed to forge weld - Chileforge.com He is out of Wimberly, Texas. He was at the Balcones Forge meeting last Saturday and had his single burner forge. He also sells a couple of different two burner forges, all of which can be found on his website. He said that they will reach welding temps without a problem. I personally have zero experience with propane. Hope this helps, Jerry Quote Link to comment Share on other sites More sharing options...
Jose Gomez Posted July 4, 2008 Share Posted July 4, 2008 I can tell you from personal experience that Chile forge burners are outstanding. I have constructed several forges using Chile forge and Zoeller forge burners and have found both to be excellent, and more than capable of reaching welding temp. The forge that I use the most for propane forge welding is my Cliff Carroll Pro forge. They are not necessarily common, but I produce a ton of Damascus out of my pro forge and have never had any difficulty at all producing high quality welds with this forge, not to mention that it has also proven to be very fuel efficient. Quote Link to comment Share on other sites More sharing options...
