March 30, 20197 yr Entering at my own risk. Has anyone built fire pots that nest together? I am currently running a break drum forge. I have formed a pot with both firebrick and clay. The problem is clinker kills both of these materials quickly. Mainly I do small work but have also done hammers and starting to make axes. This is a hobbie and for relaxation. So, I know I need two sizes of fire pots. I have made cardboard templates. One "nests" very well in the other. Space will not allow two forges and I'm lazy and cheap. I would like to remain as compact and efficient as possible. In looking for answers it looks like 3/8" to 1/2" metal is used. The size of pots are sizes I have found I like through experiments (clay needs repair often) and looking at std sizes. Two complete fire pots & plumbing is the conventional answer and doable but a pain to change and store. Am I headed down the wrong path? All oppinions would be appreciated. Papy
March 30, 20197 yr Author Ok here is pict's of the mock up. Things fit a lot better before I forced the card board over the 2" pipe. I like the screen on the tuyere to be up off the floor of the pot. This seems to help with the clinker produced with the Tractor Supply anthracite. I was planning on running 1/4 x 2 or 3 as a lip around each pot. Pipe would be welded to the large pot and the small pot would slide over.
March 31, 20197 yr I would have to say you are "thinking inside the box". I also see no reason that won't work. Be sure to let us know how it goes when you do it.
March 31, 20197 yr A fellow who posts on the "Sandbox" email list name of Bruce Freeman designed and I believe had built, nesting forges but not for the same purpose. He wanted to be able to carry a number of forges in his trunk at once. Rather than nesting fire pots how about making the two sizes fit the same hole in the forge table so you can change them out easily. With a LITTLE care the tuyere should drop into the air supply for no changes besides the pots. Frosty The Lucky.
March 31, 20197 yr Author Thanks for the thoughts Frosty I thought about two pots and I agree a rubber Fernco connector would be easy enough. Just trying to condense everything. Not sure which way I'm going but it's time to upgrade!
April 1, 20197 yr Actually, what you are attempting is redundant and not necessary. All that you are attempting can be done in one forge with proper fire control. Using water to control the spread of the fire, you can pull your green coal in to make your fire as narrow as you need, and move it out to make it as wide as your firepot will allow. Learning Fire control is the first step and the key to your problem. Hope this helps
April 2, 20197 yr Author Point taken Anvil. Water has not been friendly when poured on soft hot fire brick. It's time to upgrade and relearn. Thanks
April 3, 20197 yr if you use a watering can it shouldn't be a problem. drill a few holes on each side of the can. Then you can control the amount of water.
