racer3j Posted June 22, 2008 Share Posted June 22, 2008 (edited) Last week I bought a Harbor Freight 500# hydraulic lift table thinking it might make a versatile mobile and stable anvil stand. Shipping weight= 107 pounds. I gave thought to the examples and advice I saw here and returned it today. Yesterday I turned 62. In a large portion of my life I have battled chronic low back pain which I only made much worse in my racing. Surgery, PT, drugs, huge needles haven't done much. I talk about this again because it was all I could do to lift the carton from the ground to my 4WD S-10 Chevy( I am actually a Ford truck man, but that is another story)- a lousy 100 pounds and meds and gritting my teeth barely got it done. The kid at HF picked it up and handily carted it back into the store. I am not confident that I will be able to easily and safely move my 196+ V & B(actually a Brooks- bought out by Vaughan) even on a stand with a wide spread base. So, as I suggested in another post, I am serious about the number two Delta Future 100 pound anvil. I have found few reviews but at least one owner commented about a bit less hammer return and quiet. I haven't hit my anvil with anything so it is literally new and untested and I would not know what I am sacrificing by the change. All comments and written information indicates that as heavy as you can afford is best. That will not work for me. I am close to Centaur, so shipping will be quite reasonable. I still have not connected with getting my pics in the gallery so a kind person might just let me email pictures and then post for me. So, visit the tailgate of my anvil hauling S-10, if you get the hint.jet--AND PS-my nickname is Mike and I am just going to go with that from now on. If I tell you the real name I have to kill you. Edited June 22, 2008 by racer3j Quote Link to comment Share on other sites More sharing options...
keykeeper Posted June 22, 2008 Share Posted June 22, 2008 Sorry to hear that, if I lived closer, I'd buy that anvil, then build a mobile stand for it. Have a bad back myself, mess it up on a frequent basis. Anvil that size needs it, unless it's a permanent mount in the shop. I work outside also, and have to move everything out to work. I guarantee that a properly built, well thought out mobile stand, would work, if a person wanted to put the time in, and be more stable than a hydraulic lift table made out of sheet metal from the Pacific Rim Import Tool store. Their tools are cheap for a reason, mostly economic sustainablility. People are happy with the xxxx as long as it lasts a while. Then they just buy another. Total ruination of society, IMHO. Good luck in whatever you do. -aaron Quote Link to comment Share on other sites More sharing options...
Mills Posted June 23, 2008 Share Posted June 23, 2008 I fabricated an 'Off road' mount to put my Miller 35 on. This enabled me to wheel it down the sidewalk and into the grass where I needed to weld. The heart of it was a pair of front wheel bearings for a standard front spindle. This allows for a lot of bearing surface and SMOOTH operation. I believe you could fabricate one out of your experience in racing to make a well balanced three point stand. I suggest this since you have trouble with 100 lbs or less, seems you'd need to back off to a 20 lb anvil in order to transport. Marines stole the blacksmith creed "adapt improvise Overcome" :) Quote Link to comment Share on other sites More sharing options...
welder19 Posted June 23, 2008 Share Posted June 23, 2008 There are a lot of good mobil anvil stands that I have seen on the forum and in the blueprints, I would suggest you you look into building one, I can't give you any specific plans since I am fortunate enough to not have to move mine so I use good old fashioned oak logs. If I had to move it around though I would build a mobil stand though, verses giving up a large anvil for one I could lift, you can use a big anvil for small jobs but you can't use a small anvil for large jobs. Just my opinon, good luck. welder19 Quote Link to comment Share on other sites More sharing options...
jayco Posted June 23, 2008 Share Posted June 23, 2008 I've never tried this, but I wonder how one of the heavy duty carts they use at Lowes and similar stores would work as a way to mount an anvil on wheels? Some have a 'braking' device built in as well which would come in handy. Might be a design worth looking at.........wonder what they do with the ones with bad or broken wheels? James Quote Link to comment Share on other sites More sharing options...
