help construction digging homemade bar
Angiolino: How secure do you want your gate to be? If you used bolt together clamps as shown in your above pictures I could have taken the gate apart with the 6" adjustable wrench I used to carry in my back pocket if I wanted to get through it. If you build a gate with nuts and bolts it can be taken apart with a wrench or sharp chisel. Yes?
You have a welder in your shop don't you? Build the gate and posts in your shop then install them on location.
Me gustaría usar el sistema de fijación con pernos porque, en el lugar donde debo colocar la barrera, hay un terreno en un sitio remoto y estrecho sin electricidad, no tengo un generador de corriente eléctrica, utilizando el sistema de carpintería de metal y las mordazas atornilladas. Podría transportar los diversos elementos de ensamblaje con mi carro viejo, de lo contrario tendría que alquilar una camioneta con costos de transporte adicionales, la barra para la excavación que aún no me he dado cuenta, ya que en mi área hay un lugar perdido y no hay muchos recursos, alguna idea? gracias por las sugerencias correctas
I would like to use the bolting system because, in the place where I have to place the barrier, there is a terrain in a remote and narrow place without electricity, I do not have an electric current generator, using the metal joinery system and the jaws screwed. I could transport the various elements of assembly with my old car, otherwise I would have to rent a truck with additional transportation costs, the bar for the excavation that I have not yet realized, since in my area there is a lost place and not There are many resources, any ideas? thanks for the correct suggestions
https://www.cantierepro.com/ponteggio-tubi-e-giunti-tubi-innocenti.html
https://simplifiedsafety.co.uk/guardrails
https://www.totalsitesupplies.co.nz/product/buy/shisham-burke-bar/
