NateHMirage Posted November 21, 2018 Share Posted November 21, 2018 In the search for itc 100 replacements(price) I had learned the original formula was near 70 percent zircopax and 30 percent kaolin. When shopping i came across a high zirconia kiln wash from "The Ceramic Shop" and went to thinking. It has already been tested and formulated and its cheaper per pound.... So i bought a box and some zircopax and kaolin. My recipe was one cup wash, a third cup zircopax and one sixth cup kaolin. The mixture dried rock hard and seems to be very durable. Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 23, 2018 Share Posted November 23, 2018 Nate: You're wasting time trying to invent something without knowing what it is, how it works or what the alternatives are. ITC-100 IS a kiln wash though not designed for what we need in a propane forge. It's intended to keep things from sticking to the inside of commercial furnaces. The kiln wash you bought might have been what you were looking for. Did you read the label? What's it's stated purpose? Most kiln washes for kilns are to prevent glazes from firing to the inside of the kiln. It's usually a release agent not an IR reradiating agent though they do make ceramic's kiln washes that are. If you want to go with a decently effective home brewed kiln wash read up on the threads posted here. I don't recall the name but I'm sure someone in the gang will come to our rescue. ONe of our members in Nederlands IIRC was doing some pretty high end experiments and having impressive results running mixes of IIRC, 97% zirconium silicate to 3% Bentone. Bentone being a bentonite type clay available where he lives and Zircopax is a comparable product. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
MotoMike Posted November 23, 2018 Share Posted November 23, 2018 Not sure the cost of the chemicals required to home brew your own reradiating kiln wash, but Plistix is not expensive comared to ITC100 and some claim it is superior. Quote Link to comment Share on other sites More sharing options...
NateHMirage Posted December 8, 2018 Author Share Posted December 8, 2018 Frosty, the kiln wash i bought was a high zirconia mix which i further enriched with zircopax as a reradiating process. The wash was from the ceramic shop or store i think. Its a website titled that. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 8, 2018 Share Posted December 8, 2018 It should be good then so long as you didn't add so much zircopax there isn't enough binder to stick it to the forge liner. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
