ddan7 Posted May 13, 2008 Share Posted May 13, 2008 I just bought a new anvil at an auction. It's a 50 pounder that I got for $55. It's much, much better than the 9 pound I-beam I just replaced. The hammer bounces back nicely, which is a new experience compared to the old "anvil". I know that it's pretty small and probably just barely adequate, but is there any specific way to tell what it's made of? I want to make sure it's not cast iron. I can't find a single marking anywhere on it. I added pictures to the gallery if it helps. Hopefully, they'll appear below this message: Quote Link to comment Share on other sites More sharing options...
Ian Posted May 13, 2008 Share Posted May 13, 2008 I've heard of a few non invasive testing methods, one of which you've already tried (and because you say the hammer bounces back nicely makes me think it's not cast iron) the other is sound, cast iron sounds dull compared to the 'ring' of steel so how did it sound when you hit it with the hammer? If all else fails you can spark test it, cast iron has dull red sparks that don't split. Could someone else confirm what I've said? 12 hours at work with a ten mile bike ride chucked in means I'm tired and a bit foggy Quote Link to comment Share on other sites More sharing options...
pete46 Posted May 13, 2008 Share Posted May 13, 2008 Ian , You Only Work'n Half Days Now? :rolleyes: Quote Link to comment Share on other sites More sharing options...
cbl4823 Posted May 13, 2008 Share Posted May 13, 2008 Its just some generic anvil, looks cast to me Quote Link to comment Share on other sites More sharing options...
covforge Posted May 14, 2008 Share Posted May 14, 2008 Ian is right. If the hammer bounces it's probably steel. Cast doesn't bounce or ring very well. It's more like a thunk. Travis Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted May 14, 2008 Share Posted May 14, 2008 If the anvil gives you someething better to work with you got a bargain. Quote Link to comment Share on other sites More sharing options...
Glenn Posted May 14, 2008 Share Posted May 14, 2008 It's much, much better than the 9 pound I-beam I just replaced. I think you just answered your own question, it is the best anvil YOU own !! Build a fire in the forge and enjoy life. Quote Link to comment Share on other sites More sharing options...
metalliferous Posted May 14, 2008 Share Posted May 14, 2008 If it really does have good rebound, it must be some kind of steel. Cast iron is completely dead under a hammer blow. It may be cast steel, but that's a whole different animal from cast iron, and in any case, if it works, it's good, since the whole point of it existing is to work. Quote Link to comment Share on other sites More sharing options...
Quenchcrack Posted May 18, 2008 Share Posted May 18, 2008 I started my metallugical engineering career in a grey iron foundry. I remember separating the grey iron castings from the ductile iron castings by picking them up with a steel hook and tapping them. Grey iron has a dull "thwock" where ductile iron rang like a bell. Cast steel also rings but it has much better rebound than the ductile iron or the grey iron. Quote Link to comment Share on other sites More sharing options...
philip in china Posted May 18, 2008 Share Posted May 18, 2008 If it is rebounding it is steel. We have several cast iron anvils here and believe me you would never confuse the two materials. If it is rebounding and better than the old one - so what? Get on and see what you can do on it. That is what matters! If the thing is made out of toffee who cares provided you get good results. Quote Link to comment Share on other sites More sharing options...
David E. Posted May 20, 2008 Share Posted May 20, 2008 Check front and back, under the bick and heel for square holes, that will tell you if it is wrought iron with a steel face. The holes were for the tongs to hold it during forging. The cast iron anvils dont have these holes. Quote Link to comment Share on other sites More sharing options...
