brian Posted April 22, 2008 Share Posted April 22, 2008 Has anyone got a simple way to fix a mirror in an iron frame? Have been racking my brain but can't come up with a solution that doesn't involve drilling holes and tapping threads. Quote Link to comment Share on other sites More sharing options...
MRobb Posted April 22, 2008 Share Posted April 22, 2008 Not sure what the problem is. Do you have any pics? A picture is worth a thousand words. Quote Link to comment Share on other sites More sharing options...
brian Posted April 22, 2008 Author Share Posted April 22, 2008 Not sure what the problem is. Do you have any pics? A picture is worth a thousand words. Sorry ,no pictures yet ,haven't made the frame until I can work out the simplest way to fit the mirror. Thought I'd start with a square frame of 1 1/2 by 3/8 flat bar ,just a small frame 12" square . Quote Link to comment Share on other sites More sharing options...
MooseRidge Posted April 22, 2008 Share Posted April 22, 2008 One of the methods I've been working on for holding glass in metal frames is a form of bracket. It's a simple "U" of steel riveted through the center to the outside frame. The walls of the "U" are dependent on the weight of the glass to secure (12ga or 16ga usually) and can be bent cold. A thin slice of close-cell foam protects the glass. I would bend the back tab using a torch (to prevent strain) to a 90 degree angle and the front tab to a 45-60 degree angle. Insert the foam and the glass, then bend the front tab to secure. Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted April 22, 2008 Share Posted April 22, 2008 just made one and u did it like the factory jobs ... i used gorilla tape to hold it in.... you can make a ledge to set the mirror into then tape it in .. it should last .... Quote Link to comment Share on other sites More sharing options...
rusty_iron Posted April 25, 2008 Share Posted April 25, 2008 Gday Brian, You could get some u shaped Alum channel, but you would still have to screw it on. Or you could use small angle for the frame, either with tabs welded to it to hold the glass in or weld some angle to the back of a frame to form the U channel. Pad the glass with foam, felt, rubber or some such. Hope this helps. Rusty_iron, Brisbane, Oz. Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted April 25, 2008 Share Posted April 25, 2008 I used to make a nice wooden frame that fit snugly into the metal frame and then just use brads or small screws thru predrilled holes in the frame, the frames were just square with scroll work around the outside. and I covered the mirror with two layers of 2 inch masking tape, one cross ways and one up and down and then cut out a desing with a razor knife and bead blasted the design carefully, then removed the tape and cleaned the mirror. Presentation mirrors for different Local Organizations. Also used to make trophies for different organizations, ie: an old piston with one place melted off at the top on a wood base for hard luck trophy for car club, etc. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted May 6, 2008 Share Posted May 6, 2008 Consider the thickness of your glass ( say 1/4" plate mirror ). Experiment with some small square heated and forged on the edge of a piece of 1/4" stock ( wrapped around the edge ). See if the wrapped square fits over the edge of the glass easily. If not, put the square back over the 1/4 stock and tap the edge part ( cold) and see if that improves the fit. you should be able to find the right combination of thickness to fit over the edge of the glass in this manner. Just my 5 Quote Link to comment Share on other sites More sharing options...
case Posted May 6, 2008 Share Posted May 6, 2008 or just silicone it in.they glue fish tanks together with it and it holds. Quote Link to comment Share on other sites More sharing options...
mcraigl Posted May 6, 2008 Share Posted May 6, 2008 Case has it right. Silicone will hold the mirror better than any sort of tabs. Just design your frame so that you've got enough frame/mirror overlap (say at least 1/4") then put a small bead of silicone on the very edge of the mirror and "set". That's how we would've done it in the glass shop I worked in anyway. Let it cure overnight and voila! You're good to go. Quote Link to comment Share on other sites More sharing options...
adam cyphers Posted May 8, 2008 Share Posted May 8, 2008 hello all its been awhile since i posted...i do flat glasswork for a living and case is right...silicone is your best bet.holds great and sets up fast.cheapest you'll find out there too.just my 2 cents..hava great time. Quote Link to comment Share on other sites More sharing options...
Candidquality Posted May 15, 2008 Share Posted May 15, 2008 (edited) There's a few pieces of brass plate around here(1/8"). They came in with a mirror coating on one side. I'm not sure how you locate that particular kind of plate stock, but I don't believe it's uncommon. Great thing is that you don't have to worry about breaking glass at any point. And you could easily drill and tap it if needed. Or work hot steel around it to hold it in place without too much trouble. Just a thought. Edit: I just asked around here, it was order long ago, but it's chrome plated brass. No one can remember a price, but if it's the right material for the job.... Edited May 15, 2008 by Candidquality Quote Link to comment Share on other sites More sharing options...
brian Posted May 16, 2008 Author Share Posted May 16, 2008 Silicon sounds great.......thanks to all. Quote Link to comment Share on other sites More sharing options...
