7" Indian Chief vise
Scored big with this one.
The pic is at a bad angle but it is a full 7" vise. It has a oiled gold patina from the anti rust coating they use to put on them. This thing is gorges. Its a #140 7" vise it makes my #125 6" look tiny. Honestly I cant believe I found a 7" vise let alone an indian chief. It show so little sign of use I am shocked. What are your thoughts on value and rarity?
I picked up 7" 6" 5 3/4 vises 2 champ 10" 400 blowers and a champ 8" blower. Cost me $900.
20180309_125851.thumb.jpg.2b787d520871b4ef4f843e8a13ea3fb5.jpg20180309_125803.thumb.jpg.1fe6fcce1e7336c0d86bfa2194722e37.jpg20180309_135850.thumb.jpg.7324d8ce829674a238818208b6900464.jpg20180309_125824.thumb.jpg.a529711abcb7c7b1bcc888f73e9383c8.jpg
Wow, nice score! I think the price is good for all of that. Especially up here in the NW.
I have a 7'' Columbian  which is good for some things but a bit heavy and slow for most of the work that I do.
My main vise is a 5 1/2'' Indian Chief that I like for it's nearly perfect size and heavy construction. As a result, I've worn out the screw box and  had to built a new one to replace it.
Those two as well as an 4 1/2'' Iron City vise are the only ones that I have that have a makers mark.
Anyway , it sounds as if you made a good score for all that for $900. Let's see the rest of the pile.
Every shop should have at least one excessively large vise mounted excessively well for "excessive" work needs.   Having a smaller faster vise for regular work is a good idea too.  I like to have 1 of each mounted at differents ends of my work benches.         I also have a large vise attached to the shop framework (telephone pole set 5' into subsoil and concreted in).
Lovely vise; my largest is only a 6.5" Columbian ---but I bought it at Quad-State one year for US$50 in good working shape but needing the spring and mounting brackets.      (It's the one tied into the building). I am so lucky that I tooled up in Central Ohio back before the prices went crazy! (And before I moved to tool poor NM)
