The Alchemist Posted January 20, 2018 Share Posted January 20, 2018 Is there any way to clean flux from a dense ceramic floor in my gas forge? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 20, 2018 Share Posted January 20, 2018 thousands of ways: laser ablation, sand blasting, grinding---many will be more expensive than replacement. Of course it will depend a lot on what was in the flux; there is more than one type you know. Some people have suggesting using a tray of clay based kitty litter to catch flux and prevent it from getting to the floor to help avoid that issue in the first place. Quote Link to comment Share on other sites More sharing options...
The Alchemist Posted January 20, 2018 Author Share Posted January 20, 2018 It was z-weld flux. Quote Link to comment Share on other sites More sharing options...
Frosty Posted January 21, 2018 Share Posted January 21, 2018 Is the flux dissolving the forge floor? If not leave it till there's enough to scrape it off while molten. Borax based fluxes are water soluble but you probably don't want to soak your forge in water. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
