Stormcrow Posted November 17, 2017 Share Posted November 17, 2017 I don't often work on blades that I didn't make myself. However, I agreed to do a re-handle/re-sharpen job on a Collins engineer bolo mostly because I wanted to get to check it out first-hand. I took waaaaay to long to do the job, though the work itself went fairly quickly. I had thought that these were WWII-era, and have found since then that they started making them pre-WWI. The bolo wasn't in terrible shape, but definitely wasn't pristine. The owner picked it up for $25. It had cracked handle slabs and was missing a chunk from one, and there were some pretty deep notches out of the ax-like edge. It looked like re-sharpening had altered the profile a bit. I started out by grinding the heads off of one side of the brass handle rivets and removing the slabs. There was no glue/epoxy/cutler's resin. The handle wood was untouched by rot, though cracked from impacts. I think it is probably rosewood. engbolo01 by James Helm, on Flickr I drilled out the rivet holes from 3/16" (I think, didn't actually measure) to fit the 1/4" stainless tubing I was using on the replacement. The third hole was double-drilled, apparently at the factory, which made getting it sized a bit tricky as it kept catching the drill bit. Then I built a jig from poplar wood, cut out slabs from TeroTuf, attached them to the jig, and shaped them with a series of router bits. engbolo02 by James Helm, on Flickr I then cut out the 1/4" stainless steel tube rivets. Due to the tapered tang, I ended up needing to cut them different lengths. The original slabs were the same thickness throughout, so I didn't try to taper the replacement slabs. engbolo03 by James Helm, on Flickr I cleaned up rust with a wire brush on a bench grinder on the blade and a ScotchBrite belt on the tang, then attached the new handle slabs with rivets and epoxy. engbolo04 by James Helm, on Flickr Then on to working the edge. I had not intended to try to get all of the notches out, but by the time I had the bevel cleaned up, most of them were gone. engbolo05 by James Helm, on Flickr This thing is truly frightening now. It's a massive blade, with a convex edge that will scare the hair off my arm. The owner is going to have to make sure he hits what he's wanting to, because it will tear up Jake on anything it contacts. engbolo06 by James Helm, on Flickr Should be good for another century of work now. Quote Link to comment Share on other sites More sharing options...
SLAG Posted November 17, 2017 Share Posted November 17, 2017 Mr. Helm, You did a wonderful job. (my opinion). Could you hazard a guess as what alloy steel the blade is? Your client stole it for the $25.00 he paid for it. Regards, and thanks for the view. SLAG. Quote Link to comment Share on other sites More sharing options...
Gergely Posted November 17, 2017 Share Posted November 17, 2017 Cool work, James! Bests to you! Gergely Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 17, 2017 Share Posted November 17, 2017 Sometimes it's nice to buy "damaged" items as it gives you the freedom to redo them with out the guilt of modifying a stock historic piece. I have a 1913 "Patton" Model Cavalry sabre I picked up to convert into a swept hilt rapier and particularly looked for a "damaged one" for that reason. (Mine was made for the Great War, 1918 stamped IIRC) Quote Link to comment Share on other sites More sharing options...
