blacksmith-450 Posted November 5, 2017 Share Posted November 5, 2017 After making a hole in my forge floor with Borax, I try to have a bullet proof solution! What do you think of the idea of putting a ceramic tile between wool and kast-o-lite? Or a soft / hard firebrick? I take your suggestions. Thank you ! ... Maybe I had not made my layer of kast-o-lite quite thick, see the damage. Quote Link to comment Share on other sites More sharing options...
Everything Mac Posted November 5, 2017 Share Posted November 5, 2017 I've heard of putting a stainless steel tray in the bottom of the forge before. That might be worth doing. Andy Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted November 6, 2017 Share Posted November 6, 2017 Kast-0-Lite is resistant to flux. If you have flux problems with your floor you are probably using to much flux. I weld Damascus billets in my Ribbon Burner forge with no flux. You will need a reducing flame and a Pyrometer. Let me know if I can help you. You can find my e-mail addy on my profiles page. Wayne Quote Link to comment Share on other sites More sharing options...
blacksmith-450 Posted November 6, 2017 Author Share Posted November 6, 2017 9 minutes ago, WayneCoeArtistBlacksmith said: Kast-0-Lite is resistant to flux. If you have flux problems with your floor you are probably using to much flux. I left the control of the forge to my friend and indeed, he put A LOT of Borax. I'm happy to have ordered you some «repair potion», with a layer of Metrikote, everything should be in order soon. Quote Link to comment Share on other sites More sharing options...
bluesman7 Posted November 8, 2017 Share Posted November 8, 2017 When I weld billets I always weld on a rebar handle. Then I put a small piece of scrap at the forge opening and rest the rebar on that, so the billet does not touch the floor. I also use very little amounts of flux. My flux problems are over. If I'm doing pieces that are impractical to prop up, I fire up the coal forge. Quote Link to comment Share on other sites More sharing options...
