March 30, 20179 yr I'm contemplating a power hammer build and have an idea for one that will occupy a small space. My question or thought is, how big of a hammer is minimal for a unit that relies on gravity? What weight would one need to equal the power of a hand held hammer beating on an anvil? The addition of some springs would increase the power but by itself. for a hobby type set up, to ease the torcher on ones arm, what would be minimum?
March 31, 20179 yr The old power hammers usually start at about 25 lbs for the ram. I have a 50 lb Little Giant and I think that is minimum at times. You can always ease up on the power for lighter blows, but at a certain point, it won't hit any harder than the ram weight can produce. I like the 50 lb starting point. Good luck.
April 1, 20179 yr I built mine at #50 and like SoCal says i ease up for lighter blows mine tucks in nice in the corner its got a 5'base and 6' i beam for my truck spring to pivot on .
