KRD Posted January 30, 2017 Share Posted January 30, 2017 I just picked this anvil at an old farm. Looking for some help identifying this piece. The only markings that can be distinguished are the 10 at the bottom front and an "A" above that. Thanks for your help/ Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted January 30, 2017 Share Posted January 30, 2017 Most likely Vulcan. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted January 30, 2017 Share Posted January 30, 2017 definitely. Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted January 30, 2017 Share Posted January 30, 2017 Its a start. Vulcans are generally considered the low end of the real anvils, but its better than a rock. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 30, 2017 Share Posted January 30, 2017 DO NOT grind on the face!!!! Vulcan's have thin faces and if you grind through the thin layer of steel you have basically a harbour freight cast iron ASO. Quote Link to comment Share on other sites More sharing options...
KRD Posted January 30, 2017 Author Share Posted January 30, 2017 I appreciate the help guys! Other than using it as a boat anchor, is there a way to weld a tool steel face on the top to make it usable? The face is so chipped I do not believe it could be used to hammer on. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted January 30, 2017 Share Posted January 30, 2017 Don't even think about it unless you are VERY experienced with welding. All you "need" to beat steel is a flat spot that is the size of your hammer. Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted January 31, 2017 Share Posted January 31, 2017 That face is fine. Beat some hot steel on it, and then make a smooth block to put in the hardy hole for final finishing of the workpiece. Its a start, and meanwhile, look to upgrade. But don't discount it as an anvil. Quote Link to comment Share on other sites More sharing options...
