Hillbillysmith Posted February 12, 2008 Share Posted February 12, 2008 For those of you that have MIG and/or TIG welding machines, what gas or gas mixtures do you use? If you use mixed gas, do you have a gas mixer or do you get it pre-mixed? What gas or mixed gas (and what percent of what gases) do you use on what material? ie- TIG, 100% ARGON for everything; MIG, 100% CO2 for plain carbon steel in short-circuit transfer; MIG, ARGON/HELIUM/O2 for stainless steel. When I TIG at school, we use 100% ARGON with everything (plain carbon steel, stainless, aluminum). With MIG, we use 100% CO2. But sometimes, with the welders equipped with gas mixers, we mix ARGON and CO2. We only MIG plain carbon steel. Depending on what I'm welding is used for, I use either 100% CO2 or 65% CO2/35% ARGON (my personal preference). Quote Link to comment Share on other sites More sharing options...
clw1985 Posted February 13, 2008 Share Posted February 13, 2008 i tig with 100% argon......i hate tig, anyway......thats just me., when i mig i use a mixer you can ofcourse buy mixed tanks, i prefer a mixer though because when u switch to spray and such you can alter your mix, plus you pay for a mixer once, you pay more for mixed tanks... i usually weld at 75%argon and 25% co2 for minimal spatter and best penetration 100% co2 is alot i dont really know how that would do never tried it, but its the end result that counts. if you pass a visual inspection or a guided bend test with your preferred mix well why not. Quote Link to comment Share on other sites More sharing options...
covforge Posted February 13, 2008 Share Posted February 13, 2008 100% Argon for Tigand 75/25 for most mild steel. It depends what the wire manufacturer calls for. We use a flux core thatcalls for 75/25that is used in place of 7018on high stress jobs. travis Quote Link to comment Share on other sites More sharing options...
hammerkid Posted February 13, 2008 Share Posted February 13, 2008 100% Argon for tig. 75% argon25% co2 for MIG . Quote Link to comment Share on other sites More sharing options...
aametalmaster Posted February 14, 2008 Share Posted February 14, 2008 100% Argon for my alum mig. 75/25 for my steel mig jobs. CO2 for my outside mig jobs where i need to crank up the gas for the wind...Bob Quote Link to comment Share on other sites More sharing options...
acoop101 Posted March 3, 2008 Share Posted March 3, 2008 CO2 is much cheaper than Argon so if you can weld with it do it. That's probably why the school uses it.:p Quote Link to comment Share on other sites More sharing options...
Dr Dean Posted March 3, 2008 Share Posted March 3, 2008 Tig I use 100% argon MIG mild steel and general work is 100% CO2, it's cheaper and you can work easier with less than perfect materials, rust. Mig stainless is tri mix CO2, argon, and helium. Mig Aluminum is argon only. Most of my work is with the stick welder because I can go anywhere wind, rain, hot, or cold. Quote Link to comment Share on other sites More sharing options...
KYBOY Posted April 21, 2008 Share Posted April 21, 2008 75/25 for steel argon for aluminum Tri_mix for stainless. Thats what I was taught to use. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted April 21, 2008 Share Posted April 21, 2008 Home, 75/25 ( argon/c02) for MIG. 100% argon for TIG. Work, 95/5 ( argon/oxygen) for MIG ( hand ) 90/10 for the bot. Trimix for stainless ( mig). 100% for TIG. Quote Link to comment Share on other sites More sharing options...
hammerkid Posted April 21, 2008 Share Posted April 21, 2008 I`ve never used Tri-Mix . I usally tig all the stainless so Thats why Quote Link to comment Share on other sites More sharing options...
tompdw Posted April 21, 2008 Share Posted April 21, 2008 I use 75% argon 25% CO2 and sometimes 80%-20% for my mig. I don't have a Tig. I hear that 100%CO2 will give you deeper penetration for mig welding. Quote Link to comment Share on other sites More sharing options...
Dodge Posted April 22, 2008 Share Posted April 22, 2008 Anybody ever heard of Moon Gone (Moongone) gas for MIG? Dunno if it's a brand name or what. A guy I know said it makes it weld hotter for better penetration. My welding supplier confirmed its existence, but had little more info on it. BTW, I too use 75/25 at home and at work for solid wire on steel. At work we used straight co2 for flux core wire and submerged arc on steel, and straight argon on aluminum. Quote Link to comment Share on other sites More sharing options...
arftist Posted May 14, 2008 Share Posted May 14, 2008 I use co2 in owner tanks that I get from junkyards or the dump. Cheaper than leasing a tank, I keep three on hand, for mig. For tig I mostly use argon, but helium provides more heat for welding Al. Quote Link to comment Share on other sites More sharing options...
KYBOY Posted May 15, 2008 Share Posted May 15, 2008 75/25 for steel 100% argon for aluminum Tri-Mix for stainless. Quote Link to comment Share on other sites More sharing options...
