brianstucker Posted December 27, 2016 Share Posted December 27, 2016 Its been a while since i posted. I have been using coal. But I decided to build a propane ribbon burner forge. Here is some pics. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 1, 2017 Author Share Posted January 1, 2017 Here is the finished forge. Quote Link to comment Share on other sites More sharing options...
ede Posted January 1, 2017 Share Posted January 1, 2017 crappiew, Very nice build, and I like your color choice for the pipe. It looks like it's running great, how about giving us some specs on how you built it? For instance, it looks like you used an old water heater tank, what is the internal CI after insulating and interior length? It looks like you used about 32 crayons for orfices, what kind of WC is your blower rated for? And finally, is that a PID controller, and not just a DRO for the temperature? Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
stockmaker Posted January 1, 2017 Share Posted January 1, 2017 Also crappiew if you would, tells us about the propane interface to the air line. Thanks, and nice looking work you did. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 1, 2017 Author Share Posted January 1, 2017 I used an old 100lb propane bottle cut down to 21 inches for the forge body. The internal dimensions are 8.5 in tall and 9.5 inches wide. The pid I used is programmed to read temp. I think I got around 70$ into the homemade pyrometer. It is lined with 2in kawool . The bottom and sides is cast with mizzou. And it has a couple of heavy coats of matrikote 90 ac on it. It does great but goes through the propane. Im in the process of building a mini 11 hole version. I have already cast the the burner head. And almost have the forge body done. It was already a planned build. Its gonna go next to the big mamma version. The propane delivery orfiace is a reducing T to accept a 1/8th in schedule 80 pipe nipple. The pipe nipple it tapped to accept a mig tip. I dont recall the tap size. The mig tip is drilled to a 5/64ths. I will take photos of the next one I do. Quote Link to comment Share on other sites More sharing options...
ede Posted January 1, 2017 Share Posted January 1, 2017 Thanks for the explanation. I bet you can watch the needle on your propane tank moving down with the big mama version. What will be the ID of the new forge? That's an interesting diffuser you made kinda, shaped like a jet turbine. With your burner mounted at a tangent, is your Mizzou brought up to the other side for the flame face? I noticed that not many people are making a safety solenoid shut off switch on these in case the electricity goes out. Also, on the pine ridge burners it looks like they are using tubing pressed into a secondary baffle plate between the plenum and burner block to eliminate leaks. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 2, 2017 Author Share Posted January 2, 2017 I'm gonna put a safety solonied in my system. I just have to order them. That matrikote 90 is also a hard coat but is is weak compared to the mortar. I coated the entire inside forge with 2 heavy coats. And matrikote is also helps retard flames. It was a Long testing process with this set up. I feel confident with it. I tested the burner relentlessly. Must of had it apart and assembled 20 different times. I made it to where it can be totally disassembled accept for the cart I made. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 2, 2017 Author Share Posted January 2, 2017 I just ordered 2 safety solenoids 1 for each forge. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 2, 2017 Author Share Posted January 2, 2017 I also coated the firebrick with matrikote 90. I'm also getting ready to get a 250 gal propane tank. So I don't have to mess with these bottles. I'll just get my propane guy to fill it up. Quote Link to comment Share on other sites More sharing options...
BCROB Posted January 2, 2017 Share Posted January 2, 2017 nice , been meaning to make one for a secondary forge Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 2, 2017 Author Share Posted January 2, 2017 I want the smaller forge for better fuel efficiency. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 2, 2017 Author Share Posted January 2, 2017 Here is the propane orfiace. Quote Link to comment Share on other sites More sharing options...
ede Posted January 3, 2017 Share Posted January 3, 2017 Excellent photos and good idea on the solenoids! Tell us, what kinda blower are you using to power these? It's my understanding that a water column of at least 5 is needed for these to work decent. Also, how did you develop your jet style diffuser idea? Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 3, 2017 Author Share Posted January 3, 2017 I am using a 164 cfm blower from blacksmith depot. I am in the process of testing the small 11 hole ribbon burner. I think its getting a little too much propane. I used a 1/8 in bit on that mig tip. I think Im going down to 1/16th in on the mig tip. I got the air diffuser idea from some of these homade foundry burners. They are simple to make. I will take some pics of the one I build tomorrow. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 3, 2017 Author Share Posted January 3, 2017 Mini Burner testing. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 4, 2017 Author Share Posted January 4, 2017 Just scored a 200gal propane tank from my propane guy. It was 250$. He's gonna come set it for me in the next day or so. I figured by the time I fiddle fart around with getting these smaller tanks and getting them filled. I won't have to worry about it. And plus he will come and fill it when I need it. We use propane in our house and pre buy it in the summer and its a lot cheaper. I got the small forged with Kawool and rigidizer. Gonna line it with mizzou tomorrow. Looks like the ID will be around 5.5 inches. Sorry for the repost of the video. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 7, 2017 Author Share Posted January 7, 2017 Here is Jr. He's running like a champ. Still have to coat the inside with the matrikote 90. And a few touch ups. The inside diameter is 5.5 inches. 15 inches long. Quote Link to comment Share on other sites More sharing options...
ede Posted January 17, 2017 Share Posted January 17, 2017 I like it. Looks like you will have most of your bases covered for different size stock heating. Is that a quick disconnect for your gas supply line? Quote Link to comment Share on other sites More sharing options...
brianstucker Posted January 18, 2017 Author Share Posted January 18, 2017 Yes I put quick disconnects on them. I've got the small one painted. Still have to wire in the thermocouple. With the small fan on it it will roughly get to 1850 degrees. I could put a bigger blower on it and easily get to forge welding heat. But I'm gonna just leave it alone and strictly use it for just getting metal to temp to forge. And use the bigger one for forge welding. Quote Link to comment Share on other sites More sharing options...
brianstucker Posted April 30, 2017 Author Share Posted April 30, 2017 Update the mini burner will reach forge welding temp. Quote Link to comment Share on other sites More sharing options...
Ranchmanben Posted April 30, 2017 Share Posted April 30, 2017 That's quite a setup. Good work. Quote Link to comment Share on other sites More sharing options...
