What was this used for?
Has anyone seen something like this before?  What was it used for and what else can I use it for.  It is about 26x20x4".  It has two cast holes in the corners (about 1" dia) and one 5/8" drilled in the middle.  The two "shafts" are 3" in diameter and have cross holes of various sizes.  It has been used to hammer on as there are hammer marks on the surface.  Looking at the bottom it appears to be cast iron as it has imperfections or pitting.  A hammer bounces of it pretty nicely if that helps.  Looking for ideas and uses for this unique table.  Thanks for looking.
If you live within a hundred miles of San Diego, it is useless hazardous waste.
I will be happy to pick it up for disposal.
If NOT, then I would say it's a scrolling table, and a nice one.
But what do I know - .......
Robert Taylor
Lol, thanks but I'm in the other SD...South Dakota.
Looks like it was a surface plate at one time, but was misused and turned into something else.  Definitely a jerry-rigged set up particular to the needs of whoever was using it last.
