srobb1976 Posted April 21, 2016 Share Posted April 21, 2016 Does anyone have the big blu 65 power hammer? If so how do you like it I'm pondering getting one an cannot find how the air line attaches. Also what is the cfm an best air compressor for it thanks in advance Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 21, 2016 Share Posted April 21, 2016 Have you contacted Big Blu? What did they say about the air connection and consumption. What was their recommendation about the compressor size? Quote Link to comment Share on other sites More sharing options...
Jamesrjohnson Posted May 3, 2016 Share Posted May 3, 2016 My only advice is to do a lot of research before you buy a power hammer. There are a lot of options out there. Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted May 4, 2016 Share Posted May 4, 2016 I have a 155 Big Blu Max and I sure like it. Talk to Josh at Big Blu, like Glenn said, he can give you all the particulars. Quote Link to comment Share on other sites More sharing options...
marcusb Posted May 4, 2016 Share Posted May 4, 2016 I ran the guts out of one making pattern welded steel for one week at a class. In the week I ran it the signal switch failed, the valve for the treadle locked up and some bolts fell out but I cant remember were, it was 2 years back. Also the dies would not stay tight and kept walking out. I was interested in them myself until I got to see and use one, after that I was not impressed. Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted May 4, 2016 Share Posted May 4, 2016 You were probably using a school machine that was run unknown hours with no maintenance. I had trouble with my dies moving out too, until I started using a torque wrench and tightening them down properly. Quote Link to comment Share on other sites More sharing options...
David Kailey Posted May 13, 2016 Share Posted May 13, 2016 I own a 110. I have used it for days texturing 4" x 1/4" flat bar (800 ft of it) and have over 1200 hrs of use on it. I recommend the 110 because it will do 90% of the work you'll need. I found the 65 to be a little light. You absolutely need to torque wrench your dies in place. I oil my guides everyday and grease the gap in the lower die (prevents scale from jamming it up. I have a 7.5hp 80 gallon compressor and it seems to keep up just fine. Josh at big blu is tops!!!! I am actually looking for a 155 so yah I would recommend big blu. On Wednesday, May 04, 2016 at 6:37 PM, marcusb said: I ran the guts out of one making pattern welded steel for one week at a class. In the week I ran it the signal switch failed, the valve for the treadle locked up and some bolts fell out but I cant remember were, it was 2 years back. Also the dies would not stay tight and kept walking out. I was interested in them myself until I got to see and use one, after that I was not impressed. I feel this is a pretty unfair assessment of big blu. There are only a dozen bolts on the entire hammer. If you don't torque the dies in place they will come lose. I have a lot of long hard hours on my 110 and have never had any issues. Sounds to me like you used a hammer that had no maintenance being done and was owned buy and idiot who just refused to follow the little bit of recommended maintenance there is...........IE.....check the guides weekly, oil them daily, torque the set screwd on the die holders........... I am sorry you used a hammer in poor condition. I torque my dies rune a few minutes and check the again, never had the dies come lose. I can't imagine the irritation you must have experienced but it was not the hammers fault, it was the owners fault."if your not there for your tools, your tools won't be there for you!" Quote Link to comment Share on other sites More sharing options...
