New gas forge (Version 0.2, some pics)
MonkeyForge
I finally found a container for my ceramic wool. (could only find aluminium stove pipe and chromed stainless steel tubing for awhile). And I wanted to share my progress, see what you think.
The shell is an old flour bucket, 22 CM diameter 30 cm deep. I cut it lengthwise. On the inside I put 2 layers of 2.6 Cm ceramic wool (128 Kg/Cubic M), rigidezed, cured and then kiln washed (rigidizer/water, 75% zirconium silicate, 25% Kaolin clay) after air drying the kiln wash I fired up the forge. After that the inside had set and I applied another layer of the wash.
For a floor I use a ceramic kiln shelf coated with the same wash. (which is 1 cm thick, I will replace it with 0.5 cm thick shelf) The burner is the 1/2 inch T burner that I built earlier.
I wanted to go with a vaulted design but ended up with something between vaulted and oval because I needed to fit the 2 layers of wool all around.
I am still playing around with the burner position, I put it a bit to far back but I should be able to aim it a bit forward still. The first 10 minutes the back 2/3 are even heat and the front a bit cooler. after about 20/30 minutes I can use the front to get to forging temp as well.
Pop rivets are my new favorite fastener.
IMG-20160402-WA0000.thumb.jpeg.ee3bb129aIMG-20160402-WA0004.thumb.jpeg.8a7aee6f2IMG-20160402-WA0006.thumb.jpeg.6ea914766IMG-20160402-WA0022.thumb.jpeg.c7862b2a2IMG-20160407-WA0005.thumb.jpeg.858913df8IMG-20160408-WA0003.thumb.jpeg.98819eb3eIMG-20160408-WA0013.thumb.jpeg.98c5d03b4IMG-20160408-WA0015.thumb.jpeg.baf3a2ebc
Looks pretty good, how do you like it? With the back closed a better alignment for the burner would be closer to the front angled slightly to the back. It's not really an issue and too late to change now. I have a bunch that are a little off or backwards and yours looks like it works fine. Some of mine were just efficient ways to use up good material.
Nice job.
I like it :) the fact that it takes some time to heat all the way to the front is ok. I prefer long stock, work the end and cut. Use my hands, rather than tongs, if I can. If I have something shorter I can use tongs. When I get the thinner kiln shelf in I'll have a bit more space for the work piece and for hot burning gas. The shell gets pretty hot pretty fast (it's pretty thin) but that is ok since I am not touching it.
All in all for a first attempt (after the brick forges) I'm quite happy with the outcome.
I might get some dragons breath pictures tomorrow, just for completeness. (and because pictures of fire)
As promised, some pictures of fire. I made a couple of knife blanks (not very pretty but I will show later). I only have some thin stock at the moment (see picture) but after leaving it in the fire chamber for about 2 minutes it is a yellow hot.
IMG_20160410_205732.thumb.jpg.9ead07094dIMG_20160410_205755.thumb.jpg.e7cd26110bIMG_20160410_205759.thumb.jpg.537f013a5fIMG_20160410_205912.thumb.jpg.b1ed71710c
Looks good from here. The dragon's breath is a little orange so it's burning a little rich. Rich will keep it from scaling in the forge but is producing higher CO levels, Install a CO monitor and mind the ventilation, CO (Caron Monoxide) is a silent killer.
Frosty: CO monitor is always a good idea, though I only use the forge outside in the open air. (which is challenging in rainy country).
I have been able to forge quite a bit lately, mostly knife blanks and just practising drawing/tapering. I have been using an old sledge hammer as anvil, as well as a paving tile.
IMG-20160413-WA0006.thumb.jpeg.cb9fe7ee5IMG-20160413-WA0008.thumb.jpeg.d8c067e49IMG-20160413-WA0012.thumb.jpeg.a14ea5edeIMG-20160413-WA0015.thumb.jpeg.9166afcbfIMG-20160326-WA0002.thumb.jpeg.a4550d41c
IMG_20160414_143030.thumb.jpg.1c4eb5564d
Paving tile? Sledge hammer heads work just fine for an anvil, especially for blades. Anvils that size have been used for such for thousands of years.
I tend to always mention CO and monitors to new gas forge users.
