vern six Posted January 7, 2008 Share Posted January 7, 2008 where in se.iowa can i buy some 1095 1/4 x 2 x 20:confused: Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted January 7, 2008 Share Posted January 7, 2008 Ups will deliver almost anywhere in the usa,,most of the knife suppliers carry that steel Quote Link to comment Share on other sites More sharing options...
Steve K Posted January 7, 2008 Share Posted January 7, 2008 I don't know about that exact size but I bought 1/8" X 1 1/4" 1095 from Admiral Steel. I think it came from Chicago. I ordered it from their website. Quote Link to comment Share on other sites More sharing options...
JohnW Posted January 7, 2008 Share Posted January 7, 2008 You might find a file that size, which would probably be 1095. Quote Link to comment Share on other sites More sharing options...
EdCaffreyMS Posted January 7, 2008 Share Posted January 7, 2008 Be aware... over the last couple of years there have been some problems with 1095 steel, due to the specs being widened on it. What does this mean? It means that in order to make production easier and cheaper, the steel companies are not holding as tight tolerances on the elemental makeup of the steel as they used to. About two years ago I started getting emails and phone calls from folks telling me that they could not get their 1095 blades to harden. After some investigation, I discovered that due to some tolerance changes, SOME batches of 1095 will give you less than one second to harden them....meaning that its physically impossible to achieve. Theres no way to ensure that you get the "good" 1095, which in turn means that you may be able to harden one batch, and then the next order you get, you might not be able to harden it. Personally, I have stopped using 1095, because I don't have the time to reinvent my heat treating process with each new batch of steel. Be careful of files too. Years ago you could just about count on a file being made of 1095, but today, about the only way you can be reasonably sure is to use a Nicholson file. Their standard files are still made of 1095, and their Black Diamond variety contains the same elemental makeup as 1095, with the exception of the carbon content, which is 1.27%. Most other files these days are case hardened. Meaning they only have about .005-.015 hard surfaces. If you try to forge a blade from one of these, it will not harden, and all you end up with is some forging practice. Quote Link to comment Share on other sites More sharing options...
JDH Forge Posted January 16, 2008 Share Posted January 16, 2008 Aldo Bruno has a "load" of 1095 he is making available... Certs as follows: C. .97 M. .48 S. .25 Cr. .12 V. .029 I've got some and am going to try it out... Any recommendations on treatment? Quote Link to comment Share on other sites More sharing options...
Sam Salvati Posted January 16, 2008 Share Posted January 16, 2008 Aldo's stuff is great stuff, but it sure is a bit of work to break down the 3/8ths:D. Quote Link to comment Share on other sites More sharing options...
