ausfire Posted February 15, 2016 Share Posted February 15, 2016 Here's a funny thing. Wanted to make a small bird sculpture for a friend, so looked around in the scrap for a couple of likely pieces. I found a hook for a body and a blade off some scissors for a beak. Now here's a thing ... when I cleaned up the hook with acid (heavy gal) I saw the name cast into the hook was the surname of the person for whom it was intended. What a happy co-incidence that this bird is really personalised. I found a few more of those hooks, but this was the only one with that name. My guess is that the Sewell company is a manufacturer of electrical components or something, but I found no reference on the 'net. It's special when things like that happen. I recently made a long-necked bird for a Swedish couple. I used the handle of an old mincer, cast with 'Made in Sweden'. Little things like that add something. Anyway, here's the Sewell bird: Quote Link to comment Share on other sites More sharing options...
Daswulf Posted February 15, 2016 Share Posted February 15, 2016 Very Nice coincidence Aus. It was meant to be. Here is a nut I plan to use that i thought was funny. Quote Link to comment Share on other sites More sharing options...
Smoggy Posted February 16, 2016 Share Posted February 16, 2016 Is that a nylon insert Das, hence the do not reuse? Ausfre, What makes you suspect Sewell to be an electrical component manufacturer, I would have thought a lifting equipment manufacturer would be more likely. Especially as that nicely put together sclpture looks like a 'crane' to me ( a quick net search found Gregg Sewell Forgings with a few branches across Aus....a likely candidate? ) Quote Link to comment Share on other sites More sharing options...
Daswulf Posted February 16, 2016 Share Posted February 16, 2016 7 minutes ago, Smoggy said: Is that a nylon insert Das, hence the do not reuse? It is Smoggy, probably a wheel axle nut, just never saw one stamped like that. The little things do add a lot. Those hooks make great bird bodies. Cant wait to get out and get some that I Don't need around the farm. Quote Link to comment Share on other sites More sharing options...
ausfire Posted February 16, 2016 Author Share Posted February 16, 2016 12 hours ago, Smoggy said: Ausfire, What makes you suspect Sewell to be an electrical component manufacturer, I would have thought a lifting equipment manufacturer would be more likely. Especially as that nicely put together sculpture looks like a 'crane' to me ( a quick net search found Gregg Sewell Forgings with a few branches across Aus....a likely candidate? ) Well, I figured electrical component because these hooks are used on high voltage power lines to hold the glass insulators. Your net search could be right, Smoggy. I missed that one. Quote Link to comment Share on other sites More sharing options...
