Chris P Posted December 24, 2007 Share Posted December 24, 2007 Hi all, I guess this post will serve as an introduction too. I'm just getting into blacksmithing and I want to set up a small shop in my basement. I've taken a class, and will be taking a few more after Christmas, unfortunately, the school is over an hour away from my house.. so, I really need something at home to work with. Originally I was thinking a coal forge, but because of the cramped area and less than favorable ventilation I'm leaning towards gas now. Could someone tell me if it would be better to hook the forge up to the natural gas line in my house or to just get some canisters of propane? I'm not really sure which would be cheaper, kinda on a budget, but hoping to make more out of this than just a hobby. Thanks everyone, I hope you all have a Merry Christmas and happy holidays. Quote Link to comment Share on other sites More sharing options...
Blacksmith Jim Posted December 24, 2007 Share Posted December 24, 2007 Propane is heavier then air. It is not advised to use it in low spaces like basements, where a leak, or unburned gas could gather, causing a potentially explosive situation. Also, welcome aboard :) Quote Link to comment Share on other sites More sharing options...
Paragon Posted December 24, 2007 Share Posted December 24, 2007 I think the natural gas line would probably be too low pressure to do any good. What kind of basement are we talking about? Quote Link to comment Share on other sites More sharing options...
jjh Posted December 24, 2007 Share Posted December 24, 2007 Natural gas can work with a blower and large passages for the gas Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 25, 2007 Share Posted December 25, 2007 This will get you started till you get the forge up and running. BP0531 Forging with Clay Quote Link to comment Share on other sites More sharing options...
Chris P Posted December 25, 2007 Author Share Posted December 25, 2007 thanks for the suggestions and advice . I'll probably hold off on the natural gas as I'm thinking of building a shop and it wouldn't be equipped. just out of curiosity, would coal be a better choice in a basement... or are basements just a bad idea to begin with? oh, and as for the type of basement, its just an old fieldstone basement with basically dirt floors and 8' high ceilings. Quote Link to comment Share on other sites More sharing options...
habu68 Posted December 25, 2007 Share Posted December 25, 2007 Personal Soap Box here: Small enclosed spaces are not a good idea for any kind of burning of carbon based fuels, ie: wood, charcoal,coal, propane, natural gas, gasoline, kerosene,or old rags, unless there is well designed ventilation. CO, carbon monoxide, and CO2, carbon dioxide are both killers and both are products of combustion. Low levels of CO are cumulative in the body and require 6 days of healing of the blood stream to rid the exposure. Each new exposure adds to the previous dose. Death can be in as little as 5 min. CO is colorless and has no odor. Headache , dizziness, and disorientation, are your first symptoms. Those who try to save you will also be exposed and risk their life. In the past I owned and operated a small (20x14 foot) shop to do emission testing on cars, the shop was 2 walls and 2 garage doors with both ends open. Cars would enter one end and drive out the other. Testing took about 5min/car. My exposure was 6 days a week, I tested as an average of 70 cars a day and I used a Nighthawk Digital CO detector. While testing the doors were NEVER closed. In spite of this I would often go home with slurred speech, headaches, and memory loss. On two occasions I had brief loss of consciousness, once is was lucky enough to have a customer call the EMT's to revive me. The other time i came to on my own and sought treatment. 10 years later I still have memory and concentration problems. I WILL NOW SLOWLY CLIMB DOWN OFF MY SOAP BOX Quote Link to comment Share on other sites More sharing options...
