RogueGeek Posted September 22, 2015 Share Posted September 22, 2015 Hello all,My name is Brian, I'm originally from WV and I currently reside in Southern NJ just outside of Philadelphia.At my day job I work as a software/electronics hardware engineer for the US NAVY. I've been interested in metal working andblacksmithing for many years but only recently decided to add it to my large list of hobbies(ham radio, electronics, wood working, photography and probably a few more).My interests are mainly split between decorative metal work, that I can use in my woodworking projects,and knife making. After reading far to many threads here and on other forums I decided give it a try.I hacked together a small charcoal "bucket" forge, which looks more suited to firing a crucible than forging, andmanaged to bang out a piece of steel that at least looks like a knife.Unfortunately I live in a rather compact neighborhood that isn't exactly redneck friendly.So I have to move everything in/out of the garage every time I want to make something. Thankfully, thisproblem will be remedied shortly, as we will be moving to a rural area in Florida around the beginning on the year.Once we move I intend to setup a permanent shop outside and build a gas forge.While I'm waiting to move, I figured I would try my hand at making some blades using stock removal.I've picked up some 80CRV2 stock and I'm building an electric heat treating oven that is almost finished.If I get time this week, I should be able to get it completed and give it a test run this coming weekend.I just wanted to say "hello" and to thank everyone for the wealth of great information I've found here.Here are a few pictures of my forge, first knife, and heat treating oven.Brian++++++++++++++++++++++++++++The "Bucket". Its an old party balloon helium tank lined with a mix of fireplace cement and perlite.Working on my first knife using a mix of wood and lump charcoal.The blower is from an old heat gun that quit heating. Powered by a 12V DC power supply.Fresh from the forge, it started life as a piece of 5/8 round bar.Starting to take shape. All work was done by hand with a file. No power tools.I still need to finish shaping it and heat treat.This is my work in progress heat treating oven. Inside dimensions: 4.5"w x 4"h x 16"d120VAC, 1500w. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 22, 2015 Share Posted September 22, 2015 For your solid fuel forge you want to be able to stick the blade in the middle of your fuel pile horizontally. I don't see that in your design. Quote Link to comment Share on other sites More sharing options...
RogueGeek Posted September 22, 2015 Author Share Posted September 22, 2015 Unfortunately I figured that out after I had built it, and about half way into trying to make a knife. :-)Oh well, it is probably usable as a furnace to melt aluminum or I'll just add it to my long list of 'projects gone wrong'.-Brian Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted September 22, 2015 Share Posted September 22, 2015 Taught you somthing, lol. Look at sideblast forges, bit more "charcoal friendly" tho the lively style washtub forge works well but is a bit of a fuel hog. You will be in good company, TP is a "bit herder" as he puts it, Glenn was a pro Photogrifer, lots of woodworkers cum blacksmiths... Quote Link to comment Share on other sites More sharing options...
