Chrome or Stainless?
I had this drain strain for a while and am gonna use it for my coal grate in my forge. I am only concerned because I know some drains are chrome, and others are stainless. Can someone tell me which it is?
  Thanks
Greetings F C,
Way to thin.  Won't last long.  Back to the drawing board..
Jim
If it's stainless it probably is not magnetic, but Jim is right.
ok thanks,
  i will go get some bolts and make a grate out of them like what Glenn did.
speaking of brass, I saw a video of a guy on youtube and is a member here who casted a brass hammer head. I want to do this because i need a hammer that i can use for punches and chisels etc. My only concern is heating the brass. Is there a way I can prevent poisoning?
  Thanks
why cant you use a steel hammer with your punches
if your only concern is heating up the metal you are not ready to do any casting
Have you got $1000 to spend on PPE?
how much experience do you have of casting?
do you have the correct type of crucible?
All good points.  Actually I use a stone mason's hammer.  They are intended for striking Hardened steel tools.  They have a short handle and a heavy square head.
