Joel OF Posted August 25, 2015 Share Posted August 25, 2015 Hi folks, from looking up a few specialist paint suppliers I see that vinyl paint is the type of paint specified for use over zinc treated surfaces, typically "high build vinyl paint". Does anyone know what it is about vinyl paint that makes this the case? Just curious. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted August 25, 2015 Share Posted August 25, 2015 Don't have a clue as to why, but one wanders if they are refering to Poly vinyl acitate or poly vinal cloride? PVA is prety common water based sealer for aplications were one needs to unify the absorbability of surfaces ans stain sealing. Quote Link to comment Share on other sites More sharing options...
tzonoqua Posted August 25, 2015 Share Posted August 25, 2015 I think it's manor coatings? Am pretty sure Brundles is now supplying it so give them a ring. Quote Link to comment Share on other sites More sharing options...
yahoo2 Posted August 26, 2015 Share Posted August 26, 2015 Technically galvanized steel is coated with zinc chromate to stop those streaks of white growth from marring the look of the surface. A paint with an oil based solvent will react with this alkaline surface and form a soap like substance that delaminates the paint layer.A product like colourbond corrugated iron is not zinc chromate coated and is lightly media blasted on its way to the paint shop. The old style acid/ZnCr/resin primers had to be mixed onsite and used within a few hours and were recommended to be used in a spray booth due to health effects.I have tried to get the Urethane type coatings here with no luck at all. Quote Link to comment Share on other sites More sharing options...
Alan Evans Posted August 26, 2015 Share Posted August 26, 2015 I don't know the technical /chemical answer to your question, I have a memory of the paint history as far as blacksmiths go...A German company called Weigle und Schmidt made a paint favoured by many mainland European smiths. WS-plast M4200http://www.ws-lackchemie.de/2012-03-28-15-21-37/ws-plast-dickschicht-m-4200-en.htmlBrian Rourkes company marketed "Vinylast" paints which they also claimed would adhere to hot dipped galvanised surfaces.When they went bust Brundles took over marketing the Vinylast paints.The range of patinas that Rourkes sold all had WS in their part numbers the same as Weigle und Schmidt so I concluded it was all the same stuff, cheaper direct from Weigle und Schmidt if you are buying quantity.Alan Quote Link to comment Share on other sites More sharing options...
Joel OF Posted August 26, 2015 Author Share Posted August 26, 2015 Thanks folks. B.T.W Alan, I remember you mentioning before that you mix graphite in with your paint, is that with vinyl paint? Where do you get graphite from?*sigh* Brundles. Every time I hear that name I get this awful earworm mash-up in my head...a varition of that Ant & Dec song "let's get ready to rumble"...becomes "let's get ready ready, let's get ready ready, let's get ready to Brundles". Now it an annoy you too. Quote Link to comment Share on other sites More sharing options...
Alan Evans Posted August 26, 2015 Share Posted August 26, 2015 (edited) Do a search on here I have posted it before.my long and wittily amusing response was forbidden and lost in the ether.AlanP.s.ah it allowed me to post. Longer answer, no graphite with vinyl. I use an eggshell or semi Matt synthetic enamel. Trimite is the brand leader. I use one from the local paint factory/ retailer.Rocol Foliac flake graphite 4 B from memory ....search my earlier posts. Or from a graphite wholesaler David Hart up near Redditch.If you are passing you can have a tub from my sack at favourable rates of course! Edited August 26, 2015 by Alan Evans Quote Link to comment Share on other sites More sharing options...
tzonoqua Posted August 26, 2015 Share Posted August 26, 2015 ah yes, Vinylast was the brand I was thinking of that Brundles sells, and Manor Coatings also does a direct to galv one too. Quote Link to comment Share on other sites More sharing options...
Joel OF Posted August 29, 2015 Author Share Posted August 29, 2015 Cheers folks. For what it's worth I discovered a company in Burgess Hill called Ace Coatings South that do vinyl paint in any RAL or BS colour you want. Then all you have to do is make the client realise ironwork doesn't have to be BLACK! Quote Link to comment Share on other sites More sharing options...
