Gerber replacement - WIP
billyO
Hello all.  Hopefully it's cooler where you are (I have no understanding of how you S.O.Bs (Sole Occupation Blacksmiths) work in the summer months, especially you guys and gals in the more equatorial climates....)
Well, I thought I'd do what I do best and jump in with both feet and bite off more than I can chew....My new life gives me the ability to get into my forge on weekends, and so I thought that's e a good way to do a WIP.  As this is only my 3rd blade/knife I may make some mistakes, but I can't learn if someone doesn't teach me, so feel free to add suggestions/corrections as needed.
Here's pic of where I am at this point.  The billet is 352 layers of 1095/15N20 with a ladder pattern with grooves cut in with an angle grinder.  The chunk for the finger guard is the tip of the billet after the initial weld when I didn't pay close enough attention and tapered the billet.  It's 22 layers, and I need to do a little forging to thicken the piece for the guard line scribed.  The handle material is some spalted maple from one of my trees I took down about 6 years ago and had stabilized this spring by K&G.
xxxxxxxxxxxxxx I am a welder/fabricator so I deal with the heat either way. I cant get away from it but even when its 90+ I still enjoy working on the forge even if only for a few hours in the morning. I like the profile, cant wait to see it complete.
  • 3 weeks later...
looks like I'm forbidden from updating...
Very slow, sorry for that, but not much time these days...?
Here's a pic of what I'm planning for handle shape and rivet positions.
A couple questions/opinions/suggestions from the more experienced of you out there.  Thanks in advance:
1.  Does the pin placement look good and what color pin would you suggest to go with the Damascus and maple handle?  (or should I go through the trouble to forge out some pins with the leftover Damascus stock?  which would entail making another spring fuller but then I'd have another tool)
2.  I was planning a full tang with the bolster, but after thinking
  1. forbidden
What the F?? I can type forbidden but nothing else???
hard to see, but there's a pencil line between the
indicating the final grind pofile, the blue is the handle and the black is the finger guard
Is it as simple as fitting the bolster to the tang, mill the scales to fit the bolster, fix to tang and grind to handle shape, taking extreme care at the very end to merge the 4 pieces properly?
  • 4 weeks later...
let's try this again, here's my progress to date
Well, seeing as how I can post again, here's my progress to date.  ground, filed sanded to 800 grit and quick etch.
Not sure if I should go with the scales and a full tang, or should I use the little finger guard and a hidden tang using another piece of the same tree.  What do you guys think?
Edited by billyO
wrong picture
  • 2 months later...
 Hello all, hope the holiday season is treating you well.  Not much of a WIP, sorry about that but with only 1/2 day a week in my shop/forge for the past 9 months....
Anyway, I'm making progress and am almost ready to glue on the handle and do final shaping, but have a question about final etching before gluing the grip on.
I polished to a near mirror finish to 1000 grit, washed the blade, air dried then soaked in vinegar for about 6 hours while at work. Got home to a nice black blade, neutralized with baking soda, rinsed oxide off while rubbing with fingers under running water, and had a really dark, pattern like shown in the picture, only very uniform and not washed out at the tip.  I wanted a sharp/bright contrast, so I gave each flat a few swipes with a hardened and polished block of 4140 and 2000 grit wet/dry paper.  The pattern got really washed out and looked mottled and awful, so I re washed, re-etched for a few hours in the vinegar and after neutralizing and rinsing with mu fingers, here's where I am, afraid to go further and washing out the pattern again. Notice almost no etching on the guard and lack of black on the tip in the second picture.
Any suggestions?
Thank you
  • 3 months later...
Hello all.  I apologize for starting this as a WIP, as it really hasn't been a great one, but this weekend I finally finished the knife.  I added some ebony and bloodwood I had lying around to the handle, sanded to 5000 grit and wiped it with some citrus paste wax I had.  Learned a lot and hopefully the next one will go faster.
Thanks Theo, hopefully I'll get to your level someday.
Thanks Frosty.  Are you referring to the area near the guard where the ladder 'rungs'  don't quite go all the way across?
Here's a few more pics of other views.
