newbiesmith Posted December 15, 2007 Share Posted December 15, 2007 A guy is selling an Old Time Century Welder for $40. He said it is a 200 with a dryer outlet plug on it and that it will do 1/2" to 3/4" no problem. Good deal? Sounds like one. What should I look for in a demo of it etc..... Thanks guys. -Dan Quote Link to comment Share on other sites More sharing options...
Hillbillysmith Posted December 15, 2007 Share Posted December 15, 2007 First off, is it AC only? Or is it AC/DC+/DC-?? Ask if he will let you weld something with it first. You should prefer the AC/DC+/DC- but, depending on what rods you use, you may not care. Personally, after I tried it out, I'd buy it either way. But that's just me. Just check these forums out and make your choice Wisely my friend.Are Century Welders OK? - Weld Talk Message BoardsCentury Welder Parts? - THE H.A.M.B. $40 is $40. But for a 200 stick machine........... It peaked my interest. :) Quote Link to comment Share on other sites More sharing options...
jimmy seale Posted December 15, 2007 Share Posted December 15, 2007 burn rods and check the fine adj. that and watch for penetration but it sounds good at 40$ but weld with it first if possable some times all they need is minor parts Quote Link to comment Share on other sites More sharing options...
evfreek Posted December 16, 2007 Share Posted December 16, 2007 Hey, this should be in the welding section Just kidding. I just bought a cheap used Century stick welder. The construction is more flimsy than the big names, but it works just fine. The cord had the old fashioned "dryer" plug on it, so I needed to make an adapter. This will cost you $20, adding substantially to the price of the welder. From looking around the Internet, there seems to only be one common problem with this welder, besides general cheapness. The magnetic shunt used to limit current does not have a screw in mechanism like on the Miller Thunderbolt. This really feels cheesy, and it jams easily. It really smacks of backyard engineering. Eventually, the magnetic force of the circuit will suck the shunt to the lowest current setting so you will only get a second or so of high current welding out of the thing It's OK if all you do is low amps . Mine is almost there. The fix is to either rebuild the mechanism, drill holes so you can anchor the lever with a pin (then you are stuck with fixed settings wherever you have drilled holes) or cobble up a bracket that you can hold with a vice grip or C-clamp. You may think that paying double for a used Thunderbolt is excessive, but when you snag your apron on that stupid C-clamp, you will think twice. Or, maybe, you will smile knowingly and pat your pocketbook. Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 16, 2007 Share Posted December 16, 2007 Evfreek, your right, it was moved to welding section. Quote Link to comment Share on other sites More sharing options...
