November 4, 201411 yr I recently had an opportunity to work in L6, a steel I've not used before. I ran across a thread from another forum which suggested that L6 could be treated as an air hardening steel. I wanted to test this before getting in too deep. I took some cutoff from the project and following this http://www.bladeforums.com/forums/showthread.php/655904-All-about-L6, used the procedure in the PDF below. I had 4 coupons of the steel (Aldos L6, 0.225 not ground to remove the decarb) 1 I left as delivered 1 air quenched with no temper 1 air quenched, tempered @ 400 for 2, 4 hour sessions 1 oil quenched, tempered @ 400 for 2, 4 hour sessions Detrich at Podforge allowed me to use his Rockwell tester and we got the following results #1 tested 18 Rc +/- 1.5 #2 tested 65 Rc +/- 1.5 #3 tested 55 Rc +/- 1.5 #4 tested 54 Rc +/- 1.5 There is a very nice PDF for L6 here http://www.burgessknives.com/media/L6.pdf, and this is the procedure I used. I can't talk about the project, yet, except to say it's a hard duty blade and in the informal tests I've done so far, it's beating my expectations by a lot. Hope this is useful to folks, Geoff
November 4, 201411 yr Thank you for the info Geoff, I recently picked up some (presumably L6) bandsaw blade chunks from iron in the hat and that will come in quite handy in the future :) though I may have to rerun the test with the same parameters on my stock as it is significantly thinner!
November 19, 201411 yr I would wager your bandsaw blades are 15N20 and not L6. There seems to be some confusion over the similarity due to the nickel levels. Good test Geoff. Ric
