February 11, 20206 yr I got a nice straw color in the first 2 hour cycle, should I do a second cycle?
February 11, 20206 yr Welcome aboard... I always suggest this to get the best out of the forum. READ THIS FIRST Not enough information to even make an educated guess. What kind of steel? What temperature of the HT?
February 11, 20206 yr I would have done two, one hour cycles at 400f. You can go another hour at 400f. Not going to make much difference. You just need to come to room temp. between cycles. Straw is what you want.
February 11, 20206 yr THANKYOU I got a nice dark straw color and looks great,just whasent sure about the 2nd cycle
March 18, 20206 yr The color is only an indication of what temperature the surface of the steel go to. (not a very good indicator by the way) It does not indicate anything about how complete the tempering process is. Generally speaking, you'll want more than one temper cycle regardless of what color the steel turns. There are numerous descriptions of the changes that happen to the structure of the steel around here that would explain it better than I can. Edit: Oops, sorry, I just realized this is an older thread.
